Never knew it was so hard to change a damn bulb
Old Jan 22, 2023 | 02:15 PM
Pete6's Avatar
Can anyone give me some info on a 2017 nissan maxima sr headlights. My passenger low beam is out and I can find the high beam bulb but have no clue wth the low beam is or hiw to change it can someone please help me
Old Jan 22, 2023 | 04:55 PM
Polarisdb's Avatar
Non-LED, right?
It's part# 26296-9B92B according to Courtesy Nissan: https://www.courtesyparts.com/oem-pa...MtNWwtdjYtZ2Fz
The Sylvania finder says it's an H11: https://www.sylvania-automotive.com/...e+headlamps%29
Old Jan 23, 2023 | 04:52 AM
Polarisdb's Avatar
Old Jan 23, 2023 | 09:05 AM
Pete6's Avatar
Appreciate you taking time to hopefully help me but yeah it's led I'm assuming there's not a low beam buld
Old Jan 23, 2023 | 09:10 AM
Pete6's Avatar
Already watched that video no help
This is my headlight
Old Jan 23, 2023 | 04:38 PM
90sWheels's Avatar
I own a 4th-Gen, and I think on my car there is one headlight bulb for both high and low beams. The bulb contains 2 filaments (high-beam on low-voltage is used for daytime running lights).
Old Feb 7, 2023 | 10:20 PM
Quiver's Avatar
Did you ever figure this out? My high beam is out on one side and I also have the LED. I’ve read in a few places that the LED headlights are sealed but cannot confirm that. Curious if you had any trouble changing the bulb? Thanks in advance!
Old Feb 25, 2023 | 10:06 AM
cntd4's Avatar
Did you find a solution?
I am having a similar problem in my 17 platinum. My low beam bulb blew and it seems as if I have to replace the entire housing. The low beam seems to be behind that sealed plastic black piece there in the picture. Did you find a solution to your problem without having the replace the entire housing?
thanks
99 SE-L
Nov 27, 2004 12:55 PM
