Sticky Brakes Sometimes
Hi everyone and thank you for all your future answers. My problem started with an antifreeze leak from the radiator on the passenger side. After I replaced my radiator my brakes started sticking when I came to a stop. I can feel it in my pedal by even barely pressing down. Sometimes it won't stick but most of the time it does. When I'm coming to a stop and applying the brakes the vehicle slows down and then the brakes lock as if you slammed on the brake. The pedal returns to a normal position. I replaced the pads, and calipers, bled the brakes three times, and just replaced the master cylinder and the problem still occurs. There are no codes for the ABS Actuator and I'm at a dead end besides the brake booster has a strong vacuum. The dealership checked my front hoses which are fine as they say.
Any help would be greatly appreciated.
Replaced the two front hoses and still dealing with sticky brakes. It was good for a few miles but the problem came back. When I disconnected the booster it didn’t have the issue just hard to stop. But came back when I reconnected it. Booster has vacuum and no stored or active codes. Changing the brake booster.
DjHackStyle
69
Nov 1, 2014 01:59 PM
da God
Dec 24, 2009 06:40 PM
DaBombX
Jun 19, 2004 04:22 PM
