2017 Nissan Maxima A/C Problems & Stuff
Hi guys! I have a problem with my Maxima. The A/C panel in my car does not work at all. No lights & buttons don't do anything. In addition, sport mode does not work either. No lights on both normal & sport buttons.
Plus, the heated steering wheel & the heated & ventilated seats do not work. The button for the steering wheel does not light up when pushed & the dials for the seats don't do anything.
I checked the fuse and relays under the hood and they're all good. The heated seat fuse and the one marked "AC" are good.
I haven't checked the ones in the car yet. I recently changed the AC compressor in the car and that is when all of this happened. Is anyone here having the same issue? If so, what did you do to fix it?
Any help would be greatly appreciated.
Edit: Found the issue. Towards the left of the steering wheel, there is a panel. Remove that panel and there is a fuse board. Using a fuse test light, I narrowed down to a 10 Amp fuse called ELEC PARTS (IGN). I pulled it out and confirmed on a multi-meter that there is no continuity. I replaced the fuse and the ac panel, sport mode, heated seats and heated steering wheel are now working.
mitzache88
Mar 1, 2019 02:35 PM
Maximized Jiggs
Apr 10, 2004 07:36 AM
