y-pipe w/supercharger question
This is a direct quote off stillen's web site,
"It should not be used with automatic cars that have the STILLEN supercharger fitted." Why is that? Anybody know the side effects if a stillen y-pipe is used with the supercharger? Will a different y-pipe be needed or do I need to go back to stock once I get around to buying the supercharger? If anybody has any ideas, get back with me! Thanks!
probably because they don't wanna be held liable for anything, including not passing smog checks even tho u have CARB sticker, or scared that itll damage the clutch or tranny, or whatever stillen was smokin at the time.
works great, a must if yer boosting.
i forsee my tranny going anyways, but it should be extending the life of my tranny.. that and the slow way i drive unless provoked
i just like to cruise along and enjoy my music lately.
Re: y-pipe w/supercharger question
It's just because the stock tranny is already pushed to the limits w/ the SC. And the Y-Pipe only makes things worse. I have the SC w/ 3.33 pulley, and Stillen Y-Pipe, and 2.5" exhaust. The tranny doesn't like me very much now, but it hasn't blown up yet. I have the VB mod in my living room right now waiting to go in within the next few days. Don't worry, just get the SC.
one more question, if you can get away with keeping the y-pipe as long as you get don's vb mod (which I will have before I boost), is there a way that I could keep my underdrive pulley? I know that the supercharger gets it's power to run from robbing the engine of a little to give it a lot, something like the supercharger really makes like 80hp but you only receive like 50hp because it takes the other 30 to run it? I dunno for sure, but I guessing since the pulley is already robbing power from the accessories then, with the SC things just go all to hell? If you know anything that could answer this, I would appreciate it. Thanks guys!
:o)
Can't keep that pulley, it's robbing you of boost. It slows down all of the accessories by driving them slower, but your SC is run off of these same belts. So if the accessories are being driven slower, so is your blower, and you're boosting lower than you would otherwise.
:o)
But what if one were to get a lighter pulley just not a smaller pulley? There would be a gain there, correct? Theoretically?
Re: Re: Re: :o)
Originally posted by Keh mon
Is getting a lightened flywheel for a S/C'd car the same concept as this?
Isn't a flywheel irrelevant to a SC? Do you mean the actual SC pulley?
Re: Re: Re: Re: :o)
I know that I need a stock pulley, I was just asking if anyone had reasons why. And from what Shadow said, it makes since. So, pretty much, you could keep the underdrive pulley, but you wouldn't have the hp gains from the SC compared to the gains with the stock pulley. This all helps. Thanks again
Re: Re: Re: Re: Re: :o)
No I meant the actual flywheel. Its relevant, but unfortunately I don't know exactly how a lightened one would help. (other than the fact that less rotating mass always helps out)
Re: Re: Re: Re: Re: Re: :o)
Right, I'm not questioning that it helps. I just don't see what a supercharger has to do with it. Aren't the gains/benefits the same with or without the SC?
I'm actually not sure which would give better benefits.
trsandrew
Apr 8, 2016 06:45 PM
Unclejunebug
Apr 2, 2016 05:42 AM
