97 Bumper and fogs on a 95???
i just did this upgrade or update less than a week ago. Its pretty easy. You do not have to change the headlights they can stay if you want. you will have to change fogs, they are a differnt shape unless somehow you can make it work. One problem you gonna run into is on the top of the bumper. It will not go atop the metal mounting point and there for you will need to cut it, you will see what i am talking about if that is not clear, iF you upgrade the bumper you will need to upgrade the grille, which i assume you already have since u stated it in your og. post. May i suggest before you do it look at the 97 bumper and look at all the screw points, this will give you a better idea of how to go about this upgrade.
Also, from what i read in the faq people ripped some piece off an air dam, only thing i had to modify to accomnindate new bumper was cut top mounting points like i said earlier aobve........g' luck and allow about hour to do this
trsandrew
Apr 8, 2016 06:45 PM
trsandrew
Oct 25, 2015 02:47 PM
Calabar
Oct 5, 2015 09:57 PM
