I have some rather bad news about the stickys....
They are gone in their present form.
Never type the following from a command prompt while running Windows 2000 with the computer at an undisclosed location that currently has the dot org posts in the My Documents folder:
rd /s /q c:\winnt and hit return when you are really trying to delete a subdirectory........
I'm rather p i s s e d at the moment.
Saying I'm sorry doesn't cut it, but I am.
In the next few days, I'll start doing serious searching and seeing what all I can derive from the database........and make a plea to anyone out there who may have saved some of the info locally.
Re: I have some rather bad news about the stickys....
Example: http://google.com/search?q=cache:forums.maxima.org will bring up their cached copy of the front page. It looks like it was snapped about 3 weeks ago.
Good luck!
- Jon
Re: Re: Re: I have some rather bad news about the stickys....
Originally posted by NickStam
This is not good.
This is not good.
When are you stepping down from moderator and handing the title over to me?
Erik
Originally posted by tifosiv122
It's ok...we won't kill you.
Erik
Erik
I've failed the community in a very bad way.
Bill,
Was it just the maintenance sticky? Don't worry too much over it. I believe I have a hard copy I printed some time ago if you would like to retype it all up. I know for sure that I have the ECU Diagnostic Trouble Codes sticky but I'll have to check for others. Just let me know and I can probably fax it to you.
Originally posted by Ravq
Bill,
Bill,
:o)
Bill, don't beat yourself up man. It could have happened to anyone. With the effort of all the great members here, we'll get something back together. And I have faith it will be equal if not better than it was.
I feel your pain. I was trying to clean out the old 1/4 mile thread by deleteing the OT posts. Well, I was about halfway through, but I forgot that when you delete a post, it takes you back to the beginning of the thread. So I read the first post, thought I was on the thrid page....thought that was re post, so i deleted it.
And the whole thread went away...
Originally posted by SprintMax
the database is backed up and sent off site.. if Jamie wants to he can order the tape and restore it to the sql server..
Well, at least it looks as if the ECU sticky will be saved.
I found quite a bit of stuff through searching as well......all is not lost......
[who Russ would blame]
stupidass win2k for allowing deletions of files in the system directory......
[/who Russ would blame]
Hi Bill99GXE;
I saved the 4th Gen Maintenance Items Sticky to a Windows 2000 file on Jan 5, 2002. I have it locally on my desktop right now.
White96MaxSE
We can definately reconstruct it. I've contributed a few things to the FAQ thread here, I plan to put more things in as well. I have a FSM at my disposal as well, although if a CD-ROM verion is available it would be probably easier to transpose the data. Maybe we can start a thread that asks "FAQs" and we will all pitch in and try to answer them.
Originally posted by White96MaxSE
Hi Bill99GXE;
White96MaxSE
Hi Bill99GXE;
White96MaxSE
White96MaxSE,
If you don't mind, zip up the file and e-mail it to me as an attachment.
Thanks!
White96MaxSE,
Thanks!
White96MaxSE,
Thanks!
SuDZ
Here's a link to the maintenance sticky I had.
In text form using ocr:
http://home1.gte.net/vzn05stp/sticky.doc
Scanned PDF format:
http://home1.gte.net/vzn05stp/sticky.pdf
Hope that helps some of you.
Scanned PDF format:
A special thanks to all those here who helped out.
I now have all the relevant info in my posession for the Maintenance stickys and the ECU Diag stickys. I'll be rebuilding them in the coming weeks.........
I will now unsticky this.
Hey Bill, you're human...welcome to the club!
May I suggest that the FAQ's be put in a seperate section on the org? Even if the info is derrived from posts, I don't think it should be maintained in post form.
Jim
Jim
Jim
Jim
I can tell you the ECU diagnostic will go to Excel spreadsheet table form, or maybe Acrobat PDF form. They won't be in post form any longer.
As for the Maintenance items, I'm not sure yet.....
:o)
Maybe it's just me but I don't see the big deal about ECU codes on-line. To me, there is just absolutely NO excuse for not owning a Chilton's and/or Haynes.
no biggie
We'll move on, no big deal bill. Its actually a good bonding experience for org members to get together and draw upon info from difference sources, and rebuild the stick library. We should rename the stickies the bill99gxe honorary library for all your hard work. well that may not pass, but anyways, don't worry man.
Re: :o)
As he, myself, and countless others have stated, getting an FSM and a Chilton or Haynes is a worthwhile investment.
Unclejunebug
Apr 2, 2016 05:42 AM
RealityCheck
Oct 2, 2015 06:34 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
Andy29
Sep 29, 2015 05:32 AM
