PR CAI Question???
Old Feb 26, 2002 | 03:21 PM
wildr0id's Avatar
??PR CAI Problem??
I just finished installing my CAI, but when i start the car, by where the filter it sounds like a vaccum, very loud, and the car sounds like it is dying when i start it. then if i step on the gas a little but, it revs up a little, then the car quickly loses power, sounds like it will stall but it dose not. I had to order a new MAF from Nissan, b/c i broke the other one, could this be my problem???? I get no service engine light.
Old Feb 26, 2002 | 05:34 PM
wildr0id's Avatar
Old Feb 26, 2002 | 05:38 PM
RBa's Avatar
RBa
Re: ??PR CAI Problem??
How did you break your MAF sensor??? Did you break the mounting holes or the sensor inself? If you broke the mounting holes it shouldn't cause that much of a problem... I did the same thing and crazy glued it back...
If you break the sensor, it means trouble... If that's the case, you should be seeing the Check engine light soon... Also, it'll cause your car to stall, similiar to the problems you're having now or even worse...
OH and it's normal for the filter to sound like a vaccum.. That's what the intake is actually doing... Sucking up air!!...
Old Feb 27, 2002 | 03:58 AM
wildr0id's Avatar
I snap the corners that was holding the bolts, so thay why i had to get a new one, Nissan guy told my that i had to bring it in to so they can reprogram it, can't I just reset the compter then it should be fine????
Old Feb 27, 2002 | 05:39 AM
PIONEER's Avatar
Leave the battery unplugged it'll reset itself. I Think
Unclejunebug
Apr 2, 2016 05:42 AM
Sep 27, 2015 08:37 AM
Socalstillen
Sep 26, 2015 12:01 PM
