Springs?? what kind??
Old Feb 27, 2002 | 04:16 PM
stino4life's Avatar
i did a search already but couldnt find anyhting
what kinda springs are there for the max and how much drop do they give i want about a 2 - 2.5" drop what are some good springs and how much(im in canada)
Old Feb 27, 2002 | 04:19 PM
Vyrus's Avatar
If you just want springs (meaning no coilovers), Sprints are the only way to go. Somebody correct me if I'm wrong, but I believe they are still on national backorder after several months.
-Cyrus
Old Feb 27, 2002 | 05:56 PM
matty's Avatar
Sprints are too roufe...go with eibach/AGX but it all depends on what size wheels you have
thats what I am doin
Peace
Old Feb 27, 2002 | 06:03 PM
stino4life's Avatar
i have the 96 se stock rims right now but in a few months im chaning to 17s or 18s
i know the sprints are like 2" drop right? and the eibachs are like 1.5" right??
what kind of drop do the AGX springs have?
where can i get sprint springs from?
Old Feb 27, 2002 | 06:10 PM
matty's Avatar
AGX's are the adjustable struts you should get...there are koni's but descussions on this board have concluded that AGX's are better...H&R's will be 1.5 Eibachs will be 1.8 and Sprints will be about 2...Im gettin eibachs which are a harsh ride...H&R's will be the softest (closest to stock) ride.
Search is your friend
Old Feb 27, 2002 | 06:19 PM
iansw's Avatar
What! Sprints are STILL on backorder!?!?
They've been on backorder since last July!
I bet they're not being made anymore.
Now I'm not so sad I spent so much money on mine!
Oh...I've got Sprints on 18's, and I love them.
IanS
Old Feb 27, 2002 | 06:51 PM
lilmiller's Avatar
IanS
i just called my local speed shops here in utah and they both told me that they could get sprints in 3-5 days for 164.00 but one shop did tell me sprints are garbage....he said yeah nice drop 2 " and all but after 2-3 months the ride will be so bouncy i would blow my stock shocks so i opting for the h&r's just wating to see if either shop will work with me on prices.......so im still gonna be 4X4 it for atleast a month or two.....im rollin on 235/40zr 18's so i am right there with the rest of ya's that im worried about tire rub....
Old Feb 27, 2002 | 07:14 PM
97BlackMax's Avatar
any way you go, it would be better to upgrade your stock shocks anyways, because with any drop, the stock shocks aren't designed for it, so they will begin to wear out a lot faster, just some will last longer than others...but you'll probably be better off changing both springs and shocks at the same time, to save on labor costs
Old Feb 27, 2002 | 07:17 PM
stino4life's Avatar
how much are the AGX springs and someone said that there adjustable?? how much are they adjustable to 2-3" ??do u have to special order them or do the regular shops have them
Old Feb 27, 2002 | 07:19 PM
97BlackMax's Avatar
the AGXs that were mentioned before are STRUTS...shocks...they are adjustable in the sense of ride quality...they can be set stiff or soft
Old Feb 27, 2002 | 07:25 PM
stino4life's Avatar
so the AGXs are shocks
what are good springs to go along with the AGXs
Old Feb 27, 2002 | 07:50 PM
dmBK's Avatar
How 'bout them cliffs?
Re: Springs?? what kind??
I'm planning B&G springs with AGX shocks. will drop me about 1"6. if you go below 2", you'll need camber bolts or plates.
Old Feb 27, 2002 | 07:59 PM
stino4life's Avatar
where can i get B&G springs are they jsut as good as eibach considering they give the same amount of drop
Old Feb 27, 2002 | 08:46 PM
Heres A Thought and wha im goin with
Ground Controls - Coilovers
KYB/AGX Shocks adj.
slam it down too 3 inches... or 1 inch higher then stock ...
howeva u feel like showing off
Old Feb 28, 2002 | 12:51 AM
KWheelzSB's Avatar
www.shox.com
They will give you a lower drop than the Eibachs and a smoother ride quality.
Old Feb 28, 2002 | 08:26 AM
stino4life's Avatar
thanx bro
ill check them out
i wanna lower my car by wasaga weekend
magiconthetire
Oct 26, 2015 09:03 PM
MaxLvr21
Oct 17, 2015 12:11 PM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
followthadollar
Sep 27, 2015 01:06 PM
