service bulletins for 96 - long list of things
I couldn't believe all this stuff. I've read about maybe four on the org I think. Is all this data right?
http://www.alldata.com/TSB/41/96411757.html[/URL]
Re: service bulletins for 96 - long list of things
of the 144 items, these 81 seem pretty bunk. they're all new procedure bulletins or just noise/creak things.
99-048D JUL 00 Battery - OE And Replacement Ratings
00-064 JUL 00 CD Changer - CD Care and Usage Guidelines 00-017A JUL 00 Tools - CONSULT-II Software Update
00-033 MAR 00 Brake System - Diagnosis & Repair
00-022 MAR 00 Consult-II Software Cards
00-026 MAR 00 A/C Refrigerant Machine (ACR4) - Maintenance
99-071A FEB 00 Blower Motor - Noise
00-013 FEB 00 On-Car Brake Lathe Procedure for Steering Vibration
99-072 OCT 99 Windshield Washer Spray Pattern Adjustment
99-005A JUN 99 Brake Pad - Key Value Service Information
99-040 JUN 99 ABS Sensor - Precaution Using On Car Brake Lathe
99-034A JUN 99 Year 2000 Compliance of Nissan Vehicles
99-032 MAY 99 Front Brake - Noise (Groan) When Stopping
99-031A MAY 99 Rear Brake - Noise (Groan/Humming) After Brake Release
99-028 APR 99 Front Seat Belt - Slow Retraction
99-020 APR 99 Towing Guidelines for Nissan Vehicles
99-024 APR 99 Wind Noise Repair
99-017 APR 99 Audio Speaker - Noise (Cellular Phone)
99-010 MAR 99 Odor Coming From Sunroof Sunshade
98-110 JAN 99 Squeak and Rattle Repair - Supplies
98-097 DEC 98 Interior - Squeaks and Rattles
98-089 NOV 98 O2 Sensor Thread Repair For Exhaust Tube.
98-090 NOV 98 Rear Brake Squeak/Squeal Noise When Cold
98-076 SEP 98 Console Lid - Loose/Disconnected
98-060 JUL 98 Body Repair - Guidlines for Rust & Corrosion
98-023 APR 98 Dash - Rattle Noise
97-068 NOV 97 Door Panels - Objectionable Odors
97-060 AUG 97 Bumper Refinishing Technique
97-053 JUL 97 Park Brake Cable - Hoist Damage
97-028 APR 97 Diag. Prod. For P0731,P0732,P0733 (A/T Signal) With..
97-016 FEB 97 Audio Unit - Remanufacturer Matrix
97-012 FEB 97 Wheel Balancer Adapter Kit - Use
96-104 NOV 96 Precautions Electronic Control System Testing
96-095 OCT 96 Power Antenna Sleeve
96-086 SEP 96 Engine - Timing Chain Noise
96-087 SEP 96 Revised Procedure For Detection Refrigerant Leaks
96086 SEP 96 Timing Chain Noise
96-062 JUN 96 Remanufactured Audio Systems
96-060 JUN 96 Fog Light Kit
96-039 MAY 96 Consult UE950 Program Card-Procedure Changes
96-042 MAY 96 Consult UE951 Program Card Loading Instructions
96-032 APR 96 Engine Cranks, But Won't Start Or Is Hard To Start
96-007 FEB 96 RE4F04A Auto. Trans. - Differential Pinion Shaft Worn
PI95017 SEP 95 Remanufactured Distributor Program
PI95016 SEP 95 Remanufactured Starter/Alternator Program
95083 SEP 95 Center Console Lid Latch Replacement
PI95015 AUG 95 Paint Formula Code Numbers
PI95-015 AUG 95 Paint, Refinish Formula Code Numbers
95-068 JUL 95 Air Conditioning, R134a - Charge Amount/Lubricant Chart
95070 JUL 95 Green Or Blue Relay Caution
95068 JUL 95 R134a Charge Amounts/PAG Chart
PI95013 JUL 95 Remanufactured Bose Speakers
95064 JUN 95 A/C System Diagnostic Test Program - Southeast
PI95-008 APR 95 Enhanced Emission Inspection/Maintenance Program I/M240
PI95-006 MAR 95 Brake Noises
95-015 MAR 95 Air Conditioning - Installation Procedures
94-100 NOV 94 Recommended Fluids, Lubricants & Chemicals
94051 SEP 94 Bumper Refinishing Techniques
94-077 AUG 94 Enhanced Emission Inspection/Maintenance Program
94-049 APR 94 Body Repair Information
94-009 MAR 94 Battery Charging/Replacement Procedure
94-015 FEB 94 Paint - Contamination Identification and Repair
94-011 FEB 94 Starting & Charging System General Diagnosis
94-004 JAN 94 Differentials - Recommended Lubricants
93-109 JUL 93 Paint Finish - Maintanance/Storage Recommendations.
93-112 JUL 93 Seat Belt Extenders
93-017 JAN 93 Cassette Tape Player - Maintenance
91-096 DEC 91 ABS, Self Check - Noise
ATRATB078 NOV 91 How To Use A Pressure Gauge - Automatic Trans.
91-046 MAY 91 Consult Lithium Battery Replacement
90-090 OCT 90 Angular Tightening
ATRATB028 OCT 90 Engine Testing With A Vacuum Gauge - Auto Trans.
90-044 MAY 90 Cassette Tape Player Maintenance
ATRATB8930 OCT 89 Automatic Transmission Math Part 2
ATRATB8927 SEP 89 20 Steps To successful Auto Transmission Repair
89-131 AUG 89 Silicone And PBC Greases
ATRATB8923 AUG 89 Automatic Transmission Math Formulas
88-015 FEB 88 Cautions for Aftermarket Rust Proofing
87-172 NOV 87 Automatic Transmission - Cleaning Components.
TS87-150 OCT 87 Nissan Genuine Buckle Assembly For Use With Child Res..
87-103 JUN 87 Disc Brake Noise Information.
87-064 APR 87 Plastic Lens - Isopropyl Alcohol Caution
MAXSE5SPD
Sep 17, 2022 04:00 AM
