Have tire questions
Have tire questions
Hey,
Eventually I would like to upgrade from my stock 15" wheels to 17" wheels. I've heard alot of people talking about spacers etc, etc, and I would like to know what I will have to do to put 17" wheels and tires on my maxima. Also what do the numbers mean when it says 205/60/17? I know that the last one stands for wheels size, but what do the others mean? Sorry I'm a newbie
Chris
Chris
205 - tread width in mm. Not the actual width of the tire body (section width).
60 - tire tube height expressed as a percent. So in this case, 60% of 205mm, which is 123mm.
17 - rim diameter in inches, but u know this already
Here's a good tire size calculator to figure out some tire sizes. http://www.miata.net/garage/tirecalc.html
Most people try to fit 235/45/17 if they're going 17" rims since this is the widest tire most have fit, but lots of people have 225 or 215 width too.
Get a wheel of the right width (which will dictate your range of tire width choices) and the proper OFFSET is key. 235 width tires need 30-35mm offset and spacers might be needed if it's higher than that. Narrower tires will give you more leeway with the offsets since 35-30mm offset rims are rarer.
MR2 T'd
Jul 9, 2021 05:06 AM
