How Do You Do This?????
Old Mar 10, 2002 | 12:54 PM
JohnnyMax01's Avatar
Im Going to put in a aftermarket radio in my 01 max with the bose radio in it, how do you take the radio out??? i dont want to break anything so any advice or directions would be appreaciated thanks.
Old Mar 10, 2002 | 01:38 PM
Fazal's Avatar
Getting a running start and kick the **** out the ****er.
Old Mar 12, 2002 | 03:47 AM
PapaTango's Avatar
Re: How Do You Do This?????
After you try Fazal's neanderthal approach, take the car to a reliable car stereo shop (Circuit City/Best Buys, Joes' Stereo and Screen Door Repair, etc). They should know the proper way to remove the system without damaging anything. Second choice, buy a service manual (sometimes not written to be the easist to understand).
Old Mar 12, 2002 | 05:01 AM
psing23's Avatar
you start by removing the center vents...
you do this buy pulling up and out... its in their tight... dont worry its not on screws... just get ur thumbs inside the vent(in a place where if u pull u wont break the little adjusting thingies off) and just pull it up and out.. u will hear a snap sound that will be the vent dislocating itself from teh car... now once that is removed u take a flat head screw driver and take a thin peice of cloth and wrap it around the head... and pry up the center console peice that is around the shifter... this whole thing has to come out... once u do that u will have 4 screw exposed... on the bottom and top of the radio/climate control unit... unscrew all the screws u see and pull it out a little.. disconnect the wire harneses in the back and pull the thing out... now u will have some screws on either side of the radio/climate control unit... take these out and u will have the radio and climate control unit separated... now go on and do whatever kinda radio install u wanna do...
good luck
-danny
Old Mar 12, 2002 | 07:37 AM
BigDogJonx's Avatar
Psing23,
I have tried this over 10times. I still cant get out the damn center vents. I have tried to pull up and out with my index and middle finger grabbing the inside of the vents. That **** just wont budge.
I am tempted to get a screwdriver and cloth and try to get it in from the side, but I know I am going to mess up either the dash or the Bose radio.
There has to be way to get mine out. This one is in there really good. I mean I have pulled so hard that my fingers begin to hurt.
Dixit
Old Mar 12, 2002 | 08:18 AM
TimW's Avatar
The silent but deadly Moderator
first time...
the first time I took my center vent out (changer cable), I used a paint can opener. you know, they are hooked on one end and have a ring on the other.. I was able to find some plastic I tug on. popped right out.
The second time, that wasnt working. So I got a towel, put it in the side, between vent and dash. I DID NOT pry against the dash. I grabbed the screwdriver at the top and bottom so it wouldnt press against the dash and pulled toward me with the screwdriver. The towel was there so the shaft of the screwdriver wouldnt marr the dash. It popped right out. I dont recommend this method unless you are VERY careful.
Old Mar 12, 2002 | 10:39 AM
psing23's Avatar
my fingers hurt when i do it... i dunno i just pull up and there is that point where u think its not gonna move anywhere or its gonna break... once u reach that point just keep pulling up it should snap out... ill see if i can borrow a digi cam from someone and ill post a small mpeg of me doing it...
Old Mar 12, 2002 | 10:44 AM
BigDogJonx's Avatar
If you did that, that would be hot.
Dixit
Old Mar 12, 2002 | 10:47 AM
2000MilkedMax's Avatar
On the bottom of the vent it sticks up a little and i usually get a grip there.
Old Mar 12, 2002 | 10:53 AM
BigDogJonx's Avatar
And that is where it hurts the most on your index and middle finger when you try to pull. Cause you only have grip on your tips.
Dixit
Old Mar 12, 2002 | 10:57 AM
psing23's Avatar
Dixit
hey who says its supposed to be easy and not hurt a lil... hehe
just give it that lil extra pull just break the seal here the snap and ull be good
Old Mar 12, 2002 | 11:11 AM
Word a lil pain never hurt no one. You'll be happy after word I promise.
Old Mar 12, 2002 | 11:48 AM
xtantmaxima's Avatar
BEFORE YOU DO THIS
Open the ashtray take the liner out and remove the screw!!!!
Old Mar 12, 2002 | 12:47 PM
psing23's Avatar
Originally posted by xtantmaxima
BEFORE YOU DO THIS
damnnnn i forgot about that 1
Old Mar 12, 2002 | 01:29 PM
zeitgeist57's Avatar
Screwed up my dash
I had a GXE, and I bought a stereo install kit from Crutchfield that included the "panel puller tool". I wrapped the thing in electrical tape to prevent it from scratching everything up...but it still didn't work. I stuck the tool at the gap above the vents to remove that section, and it wouldn't BUDGE. Finally came out, but one of the metal clips bent and broke off. Still went in just fine, hasn't rattled or anything.
Worst part? It looks like a squirrel was gnawing at my dash. I'd love to remove the little scratches caused by my $hitty install, but I'm not sure how to repair the soft plastic/vinyl.
Old Mar 12, 2002 | 03:31 PM
dm7297's Avatar
by a radio from crutchfeild they give you very very very nice instructions on how to do it
Old Mar 12, 2002 | 04:10 PM
Gnstrolv's Avatar
I find that using a butter knife works well because of the rounded edges...
You have to start from the bottom. Remove the plastic piece around the shifter, then the ashtray, then you will be able to see the screws under the stereo mount. Then take out the vents with the butter knife and then you will see the other two screws and then you can finally take out the stereo. I did it myself and did not get the squirrel involved...
