strut bar question
Old Mar 14, 2002 | 03:28 PM
ZIPPIN's Avatar
Mauja He Mauja
strut bar question
i installed the strut bar, the one on the GD. after installing it i can feel that the hood takes a little more force to shut it all the way. also i noticed there is a small area that looks raised between the spray nozzles. the nozzles work fine. i am just worried if i leave it like that, if it will mess up the hood. like make a permanent bump on it ...
is it normal that the hood requires more force to shut after installing the strut bar??
Old Mar 14, 2002 | 04:06 PM
Norm02SE's Avatar
Absolutley not.I would say there is a problem.My buddy had one on his 2000 and no such thing happened.I would take it off quick before you need a new hood or cause further damage.
max2001se's Avatar
Re: strut bar question
Well I don't know which bar was on the GD but I have stillen bar in my max and have no closing problems, nor do I see a raised area. You should probably take it off - sounds like a problem.
Old Mar 14, 2002 | 04:08 PM
griffy2k2max's Avatar
Yeah defintely a problem, I would get it outta there asap, i have a courtesy FSTB, no closure problems at all.
Old Mar 14, 2002 | 04:12 PM
Padsy's Avatar
Boost.....
Re: Re: strut bar question
WHOAH!!!! Definately not right dude!!
Old Mar 14, 2002 | 09:15 PM
soundmike's Avatar
Very sound, Mike
Hey, have you tried tightening the bar first? You have two bolts on each end, turn it a couple of times so that the bar becomes shorter but not too short.
We have the same exact bar and i don't have a problem closing the hood at all.
Old Mar 15, 2002 | 04:25 AM
ZIPPIN's Avatar
Mauja He Mauja
thanks guys. i will try and shorten it. i just remember when i installed it, i did shorten the bar it to overlap the holes on the black ring..i will try again
Old Mar 15, 2002 | 04:43 AM
ItalianMax2kSE's Avatar
I have the same bar from the GD on my 2k1 and there are no such problems. REMOVE IMEDIETELY!
matts95max
Apr 23, 2025 10:44 AM
t6378tp
Sep 29, 2018 04:27 PM
dvcamp
Sep 18, 2015 10:17 AM
Johnny9595
Sep 3, 2015 05:18 AM
