corner balancing coilovers
How many of you with coilovers do corner balancing? If you do, what brand coilovers do you use. I'm guessing most get coilovers for a big drop, not performance.
For those unfamiliar with this, the car sits on scales for each tire. The weight front right/rear left should be as close as possible to front left/rear right. This helps compensate for things like the battery in the left corner plus the driver being on the same side (you should sit in the car when it's done). The advantage is left/right handling characteristics of the car are balance. Anyone autocrossing on coilovers should consider doing this. Mine were done to within 1 lb. difference, which is about as close as it gets.
I had mine corner balanced. I bought some scales for about $1100 a few months ago. The difference was amazing. It made it so that I could throw the car into a corner, at whatever speed, and still recover and pull out of the corner. If you have coilovers, I highly recommend this procedure.
Speaking of corner balancing...I learned last week you DON'T HAVE TO HAVE adjustable coilovers ie adj springperches to do corner weighting.
I'm going in Monday for my setup and I'll post what the shop does.
Cool!
Originally posted by yo_its_ok
When the car is standing still or "cruising" in a straight line, yeah that ok...when you are in AutoX or "tossing" the car around, you better be a smooth driver, otherwise your corner weighting has gone to ****, and might make the car less controlable.
I've had a couple of AutoX firsts, and I've been in Street Mod against V8's and M3s. The race shop that did the balancing runs pretty fast turbo RX7s at Sears Point and Buttonwillow. The balancing seems to help; I've never noticed any downside. Maybe I'm smooooooth ...
Nah ... the former Natl. autocross champ who ran fastest PAX of the day in Barry Chafin's corner balanced Maxima, now HE'S smooth! The rest of us just watch and learn.
Nope!
-Get the BIG PICTURE, Now ?
BTW, these numbers are pretty close to what my car was before and after balancing. In Japan the driver is on the right, so the battery somewhat balances him. Over here both are on the left, so Japanese cars typically are overweighted on the front left. This shows that the original design was for better balance than we get after the switch for export.
Re: Re: Nope!
Please remember this is not a go kart and weight shifts around 360 degrees. I understand the point you are putting across and I corner balanced my car as well, but I'll tell you right now, in a Maxima, if you apply too much throttle in the corner, and once those tires slip, the weight transfers back and forth upsetting the balance. As for springs and shocks, that's a given, but driving hard and given rubber bushings abound in 95% of Maximas autoX'd here is another word. DEFLECTION.
You can have the car balanced on a scale, and run your heart out with it, but by the end of the day, you spend more time on the scales.
Another factor Tire pressure, Tire Temp, and I can go on. As much as you try, I don't know too many that are that insane and intricate about details. I used to be like that, but after a while, I just gave up on it, cause it was too much of a royal PITA to do this every sunday after church.
Now on Eibachs and AGXs, boxed rear beam, FSTB, custom lower tie bar, I'm done, T1S on factory 17s and RA1s on my Kinesis wheels, bring it on.
-Do you understand the words coming out of my mouth ?
Original is still correct, in my opinion. All things being equal, a weight-balanced vehicle will behave moreso the same going left OR right, braking/accelerating. One that isn't balanced will behave differently going left or right, braking / accelerating.
Throw in off-camber turns, increasing/decreasing radius, turns, etc.. and the unbalanced vehicle becomes even more unpredictable.
Re: Re: Re: Re: Nope!
Man, w/ a setup like that, how can you give up AutoX or driving "spiritedly" along a nice curvy road.
I smile when I think about AutoX, and grin when I find a curvy road or on roads I know like the back of hand, and drive it @ 10/10th.
You'll miss the rush and you'll regret a softer suspension
-Peace
-Peace
It's not a lost cause!
I'm not too hot on Progress springs, you may find the ride a bit floaty @ speed, the AGXs will compliment it well.
-Peace
-Peace
-Peace
-Peace
I installed the Progress Springs on ToyLet902's car w/ Tokicos. The ride was bouncy as heck. I had Eibachs and stock shocks, and my ride was never that bouncy, but a bit harsh. I also had the chance to install Eibachs and Tokicos on wht2kmax's car, and I remember the ride to almost be like stock, but firmer.
-LMFAO @ Ladies don't appreciate the finer points of good handling.
As for the setups you describe, that is like my H&R/Tokico experience. The car was too bouncy because the rear shocks didn't do enough. The fronts were ok. Notice how everyone has a firmer AGX setting on the back than front; maybe 1/2 in front, most go 3/4 in back. That's pretty much where I run my Konis. I turned down a deal for a set of Eibach/Tokicos with camber plates because the guy wouldn't break up the set, and I won't put the blues on my car again.
LOL
LoL, yeah that line got me laughing, all my ex gfs always complained .... The AutoSexual line came about during a night out w/ my ex gf, and she claims I spend more time under the hood of my car than sleeping, and they she asked me am I autosexual ? I started to laugh, and asked her what it means.
-Peace
-Peace
As for blown struts ... I've gone through a couple of Konis (fronts), though the 2nd gen. Cattman mounts do help. That's why I'm getting bumpstops, to make them more progressive and prevent metal to metal contact. I talked to their tech people today when I ordered the stops. They claim the adjustment range on AGX is only about 1/4 that of the Konis. I wonder if anyone has actually measured this objectively? I asked if Koni could rebuild a strut for a 2" drop and they can do this. A cheap trick they told me is to cut a little of the thread at the bottom of the insert so it sit deeper and gives a bit more range. The thread extension is about 1-1/4" deep, so you could probably cut off 3/8" and still have lots of thread. I'm not sure how that would help, though, since there is a lip on the top of the insert body and I'd think that would limit how far down you go....
Re: Re: LOL
[IMG]ftp://members.aol.com/yoitsok/images/heightcontrol.jpg[/IMG]
The Body itself is an adjustable sleeve, there is a shock insert, the lower perch adjusts on the sleeve. The Spindle mount can be raised or lowered to desired height, while retaining full suspension travel.
Sorry, no education today - no shims or other spring adjustments needed. The Koni's and Eibach Pro's and nearly perfect as is.
i have eibachs and agxs i run 1 front 8 rear for racing in a straight line and usually 3 front 8 rear for other times, makes the car real stiff makes it easier to drift and its so much fun in gravel and dirt rotates perfectly. now i just need some wider wheels so i can take more advantage of the stiffer setup
NewMax03
Oct 7, 2015 08:27 AM
NismoMaxi02
Oct 4, 2015 09:09 PM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
