Tire Pressure...Please help
Old Nov 21, 2000 | 11:26 PM
MaxRod33's Avatar
I have 17 inch Falken performance tires on my Max. What PSI should I set them at. They say 44 max on the side. Thanks.
Old Nov 22, 2000 | 12:25 AM
Eric L.'s Avatar
I run 37 front // 33 rear .
Seems to work fine for me. Any higher pressure and the ride is rough as hell.
Old Nov 22, 2000 | 12:38 PM
Micah95GLE's Avatar
Yeah, that's about what I set mine for. Different tires, but should be the same results.
Old Nov 22, 2000 | 12:57 PM
kratz74's Avatar
I'd say it depends... The higher the pressure the better fuel economy and the lower (to a certain point) the better the traction for acceleration and lateral handling. I'm cheap so I keep em pumped up.
Old Nov 22, 2000 | 01:42 PM
got rice?'s Avatar
with the plus one or plus two upgrade, you should run several psi higher than the fact. recommended specs. don't run what is on the tire; t hat's only a max rating.
36 to 38 should be fine.
I ran 39 psi on 245/40/17s on the Z
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
Garrettz459
Sep 28, 2015 02:50 PM
