? on 300ZX brake upgrade.
I hear you need 17" rims for this. Why? 300zx rims are 16" as well. I think the only clearance problem is with the new caliper hitting the inside of the wheel......where it mounts to the rotor. If thats the case wheel spacers and perhaps some longer studs should do the trick right?
Aaron
Anyone have a pic of a max w/ this done?
Aaron
Im thinking so
Originally posted by SuDZ
Does it have something to do with offset?
SuDZ
SuDZ
Re: ? on 300ZX brake upgrade.
they will fit under something smaller than 17s, the rotor will only be ~11" . so you dont have to worry about overall diameters (i think someone said it could fit under 15s) you should be more concerned with the spoke design not clearing the calipers
Re: Re: ? on 300ZX brake upgrade.
Originally posted by psu max
na 300zx 16x7.5 will work as well. along with 16x7.5 koseis basically anything that fits a 90-96 na 300zx would work ... the diameter isnt as important as offset and spoke design.
http://forums.maxima.org/showthread....ighlight=300zx
i think ppl are having their doubts about 99 se's clearign with spacers. the sad thing is, you won't know if they'll clear with spacers or not until you get the Z brakes on and put on you 98's
right now, im looking into getting some used Z rims and then maybe doing the swap
Apr 16, 2020 05:15 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
