What amp needed to run two 8 or 10" subs?
Old Apr 3, 2002 | 11:11 PM
Maxtor
What amp is needed to run two 400w kenwood subs?
I will be taking a feed off the stock bose amp. What are the basic specs for an amp to run those clean?
Old Apr 4, 2002 | 01:07 PM
Mikesburn's Avatar
Re: What amp needed to run two 8 or 10" subs?
I would buy Zapco, PPI or Arc Audio, or Xtant. They are supposed to be enough to run 2 400 subs. It needs to be 2-channel amp. Not cheap -trust me!
Mike
Old Apr 4, 2002 | 04:37 PM
victor's Avatar
Re: Re: What amp needed to run two 8 or 10" subs?
Mike
hmm, those amps arew a bit on the high end side, you can probably get away with something lower, since your running the subs with them. but if you can afford those sound quality amps, go ahead and get them to run your subs too.
Old Apr 4, 2002 | 05:15 PM
LikwidVT's Avatar
Is the 400 W RMS or max? I would probably get an amp from Lanzar or another one of the cheapies. I would suggest the JBL bp1200.1, but I'm guessing the subs can't handle a 2 ohm load. That amp is about $250 on ebay
Check out Master Yoshi's listings on ebay. He's got some pretty good deals for cheap amps.
smplyamzng
Dec 13, 2015 01:19 PM
homeyclaus
Sep 3, 2015 06:15 PM
maxinout93
Aug 20, 2015 02:17 AM
TonyJr
Aug 20, 2015 12:14 AM
Slamrod
Aug 10, 2015 12:33 PM
