Addco RSB - Can you still jack up using the beam?
I just received my RSB (thanks Greg!) and looking at the install photos, it looks like the bar will be directly under the beam axle on my A32. I've read that the beam is a jack point, but looks like the bar will be in the way after install? How else can I jack up the rear?
TIA for inputs - I've been using search a LOT and this is a great forum. I've had my 96 SE 5 sp for two weeks and this board sure gets the mod bug going. The FSTB was quite an improvement.
Mark
Mark
I have wondered why not as well...it still is centered for the pressure...only thing is to make certain the car is put on jack stands at the appropriate points...I just do one side at a time for mine...probably not negative efects of still using it I just don't want to risk it on mine.
I slip a 6" x 6" x 3/8" thick plate of aluminum between the Addco and the axle and place my floor jack directly on the Addco. Use metal because I doubt if a piece of plywood would be strong enough.
I don't remmember who came up with this solution but it's been around at least the last three years.
-Mark
-Mark
Originally posted by plrod Black 95 SE
I'm not aware of the rear beam being a jack point, I don't think it is.
I read a post a while ago by the one-and-only DBM and he states that it is fine to jack the car up with the rear axle or the front engine support. Of course this is to only jack one end up at a time and put it on jackstands though. I have an addco too and get the saddle of my jack to catch the edge of the axle closest to the rear of the car. IT has been fine for a year now but, I have been planning on doing something like MarkP suggests. Good luck.
AaronL
Nov 15, 2020 11:52 AM
thatcollegestudent
18
Oct 5, 2015 02:29 PM
homewrecker
Sep 23, 2015 03:41 AM
