Stillen FSB and Air Intake Questions
I'm looking to get the Stillen front strut brace and air intake (http://www.stillen.com/). I have been checking the newsgroups to see how easy/smooth the install is and found the following common issues/complaints. I have a 99 SE Auto with ABS.
- Brackets: Some ppl had to cut into a driver side bracket in order to install the FSB, is this still the case or have Stillen fixed it in the current model?
- Air Intake: Ppl with a 99 SE mentioned that they had to lengthen the cable that connected to the air temperature sensor, this isn't a big deal (simple splice?), but again is this still the case or have Stillen adjusted the cable length?
If anyone has installed these components recently (on a 99 SE or other), let me know how it went and if you encountered these issues.
Thx
Thx
I have the stillen intake too, and when i installed it the air temp sensor was about a foot to short, so i had to cut the tape back and pretty much force it to reach, i have some slack now so its no problem, but the install is cake, its something anyone can do
Re: Stillen FSB and Air Intake Questions
Thx
Thx
aaaaaaaaaaaaaaaaaaaaaa...
i have a 99 SE-L
i just zip tied the sensor in some wiring under the intake.. you do not even see it..
and i had no trouble with the fstb.... it took 15 minutes...
Thx
Thx
vingodine
45
May 21, 2016 12:46 PM
95Maxi
Aug 29, 2015 09:38 PM
bc992164
Aug 26, 2015 12:19 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
