Mustang Fuel Pump (Walbro GSS342) is a DIRECT FIT!
Re: Mustang Fuel Pump (Walbro GSS342) is a DIRECT FIT!
Originally posted by My 4DSC
Order them up 5th gen owners.
This is a direct fit.
Actually it even PLUGS RIGHT IN!
Don't even have to cut the harness!
(i think kev will like this one if he hasn't realized it yet himself)
Do you know where I can go to get it?
which pump?
Originally posted by Y2KevSE
Walbro Mustang 255 Hi-pressure pump GSS340
You said GSS342.
You said GSS342.
Deac
I have that same pump in my Stang too, it takes a while for the gears in the pump to "break-in", I was making like 65-70psi at idle for about 7 days, now it is fine. And it will hold a steady 85psi for me on the bottle, wher my stock pump would only push 65psi.
Piece of crap... now I see GSS317 or GSS342 for the Mustang (2000) vs. GSS340 for 85-87
I told them GSS342 & what they gave me had a different p/n on it but they said it was the same (2000 mustang).
No worries, this bad boy plugs right in!
Re: which pump?
Originally posted by Deac
I dont remember the exact part# for the Walbro pump the 4th Gen guys are using but I have it and I still have'nt installed it yet...Its a direct fit for the 4th Gen guys but for the 5th en it needs some custom tweeking! TheNewCLimax is the only one who has it installed for the 5th Gen I believe. If this new pump is a direct drop in and it works ok, maybe I'll sell mine to one of the 4th gen dudes and go with that one! If we can straightenthe part#'s out. Can anyone confirm that this pump works?
Deac
Deac
I just told you the p/n and that it is a direct bolt-in/plug-in (i just installed mine last week!)
If you got the right pump, INSTALL IT ALREADY!
It is the *NEWER* Mustang pump.
Thanks!
Originally posted by IceY2K1
Didn't Deac's mechanic tell him that pump would not fit?
Originally posted by swallac2
Would someone PLEASE explain why you guys have such wood over this fuel pump? Does it flow that much better than stock? What's the deal?
Too much nitrous or air and not enough fuel = BOOM
At least that's what they thought, since Deacs' mechanic said it wouldn't fit.
Now they can safely and reliably run 10+psi or 100-shot.
These guys are pushing the limits of what the stock pump could handle and there were NO aftermarket intank pumps available.
Originally posted by Dan4614
REALLY?!?!! You can safely run 100-shot with this pump? How much does the pump cost?
Here is the first 5th gen. to run a 100-shot:
http://forums.maxima.org/showthread.php?threadid=114756
I don't know the cost.
carid
Sep 9, 2015 05:06 AM
