Help!! Being robbed. When should transmission bearings wear out?!?
If you have experience with or knowledge of when transmission bearings should go out on a 96 SE w/ manual transmission, please read on.
I have a 96 SE with 95,000 miles on it. Just 2 or 3 months ago, I replaced the clutch for friggin' $700. Now I'm getting a rolling clicking noise out of the tranny bearings. I took it to the dealer service guy I usually go to and he claimed that it was my transmission bearings and that they usually go out around 100,000 miles.
In my experience, that's bull****. Even older trannies lasted longer than that, ESPECIALLY if you had/have a manual transmission. The only thing that should go out is the clutch. I think they either: 1. Adjusted the clutch to tight causing the bearings to wear out prematurely; or 2. Forgot to replace the transmission oil or simply did not add enough when they did the clutch.
Please let me know your thoughts on or experience with this. I can't afford to spend over $1300 replacing this effer. Thanks in advance. I look forward to your responses.
Spaz96
(NOTE: I have been researching old posts. Not very encouraging but at least I know they would be charging me way too much)
Spaz96
Re: Help!! Being robbed. When should transmission bearings wear out?!?
Spaz96
Spaz96
ah ha! yet another manny tranny bearings bites the dust. Whats the count up to now? I'm the KING of the busted 5 speed transmissions and I've had every problem you can think of, from the bearings going, to blowing 2nd gear, to being stuck in reverse.
Anyway, I doubt they did anything to screw up your transmission. If anything, it was manufacturered at the factory wrong. You're lucky you got 100K out of it, most of ours went out at 60K. $1300 is about the price you're gonna pay, cause its alot of labor.
Read my post in the FAQ up above, as well as these threads:
http://forums.maxima.org/search.php?...der=descending
Feel free to ask me anything else you want to know about this tranny.
Re: Re: Help!! Being robbed. When should transmission bearings wear out?!?
Re: Re: Re: Help!! Being robbed. When should transmission bearings wear out?!?
Aaaaw, daaaayuuuum. That's not the answer I wanted. Crap! Given your experience, if I hear a low mild whirring from seemingly the front left and a rolling click from the front right (cv boot is fully intact) which bearings do you believe are the root of the problem?
That is the tranny bearings. I was having the same prob on my 96 se. I checked the wheel bearings tore apart the cv joints and everything else that I could thind of. Mine happened about 70,000 and was just 432 miles under the extended warranty when I took it in. man am I glad it would of cost me a little over 2200, (lots of internals needed to be replaced). Sorry to hear about another one biting the dust. Good luck man.
A rolling clicking noise does not sound like the tranny. My tranny got the bearing noise at 125,000 miles. It's a gear whine that is directly associated with your gears and rpm, it rises as you accelerate, and then changes and rises again when you change gear.
When the bearings do go bad, it's not like you're dead in the water. The car is still completely drivable, just very noisy. You and everyone else outside hears your gears, and they even hear you changing gears!
I finally got fed up with it and replaced my tranny with a used 99 with 50K miles. Got a new ACT clutch put in too, even though my original still had life, but who knew how long.
This is the 1 glaring weakness of the 4th gen Maxima, the 5 speed tranny bearings.
DW
DW
litch
123
Jan 4, 2024 07:01 PM
Andy29
Sep 29, 2015 05:32 AM
