What is the best aftermarket clutch kit for 4th gen
Old May 1, 2002 | 10:22 AM
jtanner@accessu
What is the best aftermarket clutch kit for a 1995 Maxima SE. I don't want to loose the factory feel though.
Let me know and thanks in advance.
Jeff Tanner
jtanner@accessus.net
Old May 1, 2002 | 10:30 AM
AdMax98's Avatar
Re: What is the best aftermarket clutch kit for 4th gen
Then get a factory clutch
I doubt you'd need anything more unless you plan on running a S/C. Plus Im sure its cheaper...I just got a new clutch for mine and it cost me $110 CDN ($70 US).
Old May 1, 2002 | 10:55 AM
dwapenyi's Avatar
Well, the factory feel can only be exactly duplicated by a factory clutch. Another advantage of putting in a stock clutch is that alot of tranny shops will guarrantee the clutch for the life of the car. Still, I went for aftermarket. I wanted somthing that could grab the engine better. The ACT does, big time.
Despite that, I think you'll find that the ACT has a very solid reputation. It's a stronger clutch, but since our clutch mechanism is hydraulic, the pedal effort does not really change that much. The way the clutch engages, though, does. Alot.
The stock clutch would have long play between when it starts engaging and when it's fully engaged. With the ACT, that play is much shorter.
I recently got the ACT, by the way
DW
Matt93SE
May 24, 2019 02:58 PM
Cant_Get_Ryte
Aug 28, 2015 06:41 AM
carlosvq30
Aug 17, 2015 11:32 AM
PhalC1
Aug 5, 2015 02:36 PM
