Spare tire mold? whats the hole??
Old May 13, 2002 | 12:46 PM
jag5311's Avatar
If you look under the car, and look where the mold for the spare tire is, there is a hole in it about the size of a coke can. What is that. I noticed some of my rattling is coming from that region, so i was going to pull the tire out and apply some dynamat stuff around the rim, cuz i think the metal part of the tire is hittin the metal mold frame. But what is that hole. Air comes out of it when my bass is on.
thanks
bryan
Old May 13, 2002 | 03:54 PM
jmax
I remember seeing a drain plug but nothing the size of a coke can. If it is realling venting that much, go ahead and seal it with damping material. If you need a hole in the future you can cut through the damping material pretty easy.
Old May 13, 2002 | 05:38 PM
jag5311's Avatar
ok, coke can may have be a little to big, but it looks to be about 2 1/2 - 3 inches across. I guess there is suppose to be a plug there. I am losing valuable air from my trunk i think
thanks
Old May 13, 2002 | 10:22 PM
jmax
You can 'fix' it the time consuming way with resin and glass. Or just cover, I mean fill it with which ever dampening material you are using.
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
JonBlz
Oct 5, 2015 06:02 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
