Racing a 2K2 Auto,,,Suggestions..
As I posted before. I will be visiting the track on Saturday, along with some So Cal ORG members.... Im just curious what you 5th Gen AUTO owners suggest to getting the best possible time.... Im just hoping to hit the 14's..high would be ok with me....Thanks guys...
Originally posted by 02MaXiMa_GLE
Will the brothers be racing each other at the track?... Huh, ansk & Kloog?... I would like to see those results, cause I also have a GLE.
G
G
G
G
..J/K little brother...The Brothers ANSKY RULE !, or just caall us , the FRANKEN - BROTHERS !
Re: Racing a 2K2 Auto,,,Suggestions..
ps - i actually do know people who will take out all their seats to get better times....
well what do you know kloogy makes a new thread and here comes Maxtor i think he wants you kloog i hope you ain't down with that
Originally posted by Maxtor
I'm surprised you already haven't?
kloog... if you can get more than 1 run try manually shifting at first, on the second run just keep it in 3. (It will still redline, just don't bog down with the throttle halfway or it'll shift prematurely)
I'm going to the track as well this weekend.
Post your times so we can compare. This will be my first, so I'm hoping low 15s or high 14s (more for the high 14s
I've just got the berk intake and got the franken mide-pipe on order, mabe I'll take it back to the track after I get the mide-pipe to see if there's any difference.
)I've just got the berk intake and got the franken mide-pipe on order, mabe I'll take it back to the track after I get the mide-pipe to see if there's any difference.
) from it drop the tire pressure in the frt to about 22/24psi raise the rear press to about 42psi have about 1/4 to 3/8 tank of 93 octane, pray for about 45/55 degrees and plenty of bite. Trac off (of course!) come to about 1200/1500 rpm (brake torque) when you see the yellows (stage "deep") and when you see the LAST yellow let go and punch it!
Let it shift and listen to roar of your Franken till you hit the traps! You can try and shift yerself @ about 6250 rpm but I really saw no gain other than I "felt" in control. My best time was .3 better than my worst. I get a bigger rush of beating everyone off the line (outta 29 passes got beat at the "tree" only 3 times with only 1 redlight), you'll actually see them move 2nd. Good luck bud, I hope you hit 14 !
l8tr -- SS
good advice SS
I've only tq. braked once and it got me a better 60' time but (like an idiot) I slowed down before the end of the 1/4 so I can't tell how much of a difference it makes--everytime my times were in the 15s it was b/c I didn't give it enough gas on the launch, you just have to go as many times as you can to get used to the traction issues
Re: Re: Racing a 2K2 Auto,,,Suggestions..
Originally posted by ssiperko
If you want "real" times leave it as you drive every day. To milk the MAX (pun intended!
l8tr -- SS
l8tr -- SS
I suggest launching just above the torque converters stall speed, probably around 1800 rpm. Hammer it down just enough to get some wheelspin, but make sure you have more traction than spin (you knew that!). That is something you'll just get the feel for.
One other thing. Make sure you keep it on the mat until you pass the second set of lights at the end. There are 2 sets of lights; one for the ET, one for the MPH. Look for the 2 yellow lines with a big "x" in the middle. Kind of like this (I hope this works):
_
X
And YES, leave on the last yellow. By the time your body processes it, and everything starts to move, the light will be green. You will see RT's around .600-.750 on average. That's usually why every other track rookie gets RT's over 1 second.
Good luck.
Damn. I can feel the adrenaline pumping already !
.. Thanks for the advice. I will be MASHING it on the last set of yellows... ! Its been years since Ive been to the track. I sold my last sports car 3 years ago, and It's been about 9 years since I visited a track.... 14's here I come ... I HOPE ...
TallTom
57
Oct 14, 2025 05:16 PM
AaronL
Aug 8, 2020 10:31 AM
Maximeltman
Sep 28, 2015 07:19 PM
