Stillen Drilled rotors and pads
Does any one know where I can get the drilled stillen rotors and pads for a cheap price. Does anyone have this combo? If you do, please list if you like it or what problems you have. THANKS!
Try www.eatrricezone.com or avalonracing.net
I have the pads, rotors and the big brakes...The only complaint I had was the fact Stillen lied to us and said the calipers would clear my stock 17" rims. NOT even close. I have 19"s now and they barely fit. But, after we got the fitting right, I must say I am impressed with the Stillen equipment. Pads don't give off too much dust either. Hope this helps.
Originally posted by Igor911
WOW $1350! I thought i can get all rotors, brakes and lines for $500 TOTAL! What did you buy?
BTW - Your rims look AWESOME!!! THEY ARE PERFECT
Thanks for the compliments ya'll.
IGOR, I bought the whole brake kit...4 piston calipers, 13.1" front rotors...pads, brake lines. You can probably get the rotors, brake lines and pads for the price you were saying...maybe even less if you look around.
Originally posted by Tanmann9
Eatricezone.com has the Stillen cross-drilled rotors\Metal Matrix pads\SS brake lines\brake fluid for $575 for 5th gen Maximas. It's not the same kit that look2me40 has, but it's nice.
, car looks sweet 2
Re: What other kinds are there?
Originally posted by asu174
What other kinds of rotors are out there? I saw the Stillen but they look too gold for me. Are there any aluminum looking ones anywhere?
but the ? is will the BIG brake kit work?
If you want a nice looking caliper and you don't want to paint it, the BIG Brake kit is your answer.
The other option would be the kit from Brembo.
yes that is the stillen kit i want! The ? is will it fit and will my rims clear the calliper??? I have stock 16" 5-spokes?
Is their anything i can do to make the stillen callipers fit the stock 16" 5-spokes? Gee... i'm soo confused now!
Igor, the brake calipers would most definitely not fit on your 16"'s. That I can promise. I had stock 17" SE rims and the calipers were not even close to fitting. The spokes were hitting the caliper. Even with spacers we could not get it to fit. The kit I got (which is one piece) came with 13.1" front rotors. I think stock is 10.5 or 11". (At least on my car which is a 2002). I had to upgrade to 19" wheels with 10mm spacers to make it work out. In my opinion, you could get the rotors and pads and use your stock calipers. If there is any doubt, call Stillen and ask them...but do not believe them if they tell you the kit (with the calipers) will fit on with your stock rims.
THANK YOU FOR ALL YOUR HELP EVERYONE!!! I just orderd my stillen rotors(all 4), axxis pads, brakelines and brake fluid!
Apr 16, 2020 05:15 AM
props to you look2me40 i thought i was seeing double.. i have the same setup except i have chrome...
good choice...the stillen sets yours off even more.. good job
