Herers a pic of the OBX headers
Check it out.
They look pretty good, OBX claims a 12-14 HP gain with these, imagine if it was that good
They say they have them for 95-01. I am going to stop by nissan on Monday and check the gasket part #'s on the 2001 and 2002. If the #'s match up I am going to order these headers and a 2001 stillen Y-Pipe. Hopefully all this works out and I get good gains on the dyno
Stay tuned.
Stay tuned.
Originally posted by Vyrus
Is that the pic of the exact Maxima ones? And how hard would these be to install?
Thanks,
-Cyrus
Thanks,
-Cyrus
Craig I don't I have my 95 anymore so nope
Originally posted by emax95
It is a pic of the maxima ones. The install is going to be a PITA but my bolts should be pretty easy to take off becuase my car is new. I paln on doignt eh install my self this time around. I have to move 2 sensors into my B-pipe too.
-Cyrus
But for most of us is is just removing 10 or so bolts, placing a new gasket in, and putting the bolts back in again, right? Do they have to be professionally tightened or anything? Just curious because I don't know wether most headers are a D-I-Y project of not. I would assume so, but I also know it can be much more tricky than it looks, right?
-Cyrus
-Cyrus
Sure you just have to take some bolts off and put new ones on, the problem is getting to these bolts and removing them. The bolts them selves are TQ to 22 lb's but heat and rust over time will make these bolts very hard to get off. The bolts are the same type that are on the Y-pipe but they are in a much harder place to get too. When you put the gasket on you have to TQ the bolts in a certain order, you will need a manual with a diagram. On some car's putting headers on is a sinch on others it is really hard(IE maximas).
Thanks,
-Cyrus
So how much would a shop charge to put these on? Around the same price for a Y-pipe?
Thanks,
-Cyrus
Thanks,
-Cyrus
It takes a mechanic about 6-8 hours to get these on, I payed $200 ($25 a hour) for my 95 header install. The bolts on my 95 would not budge. This install is a LOT harder to do then a Y-pipe install.
Originally posted by Craig Mack
I feel headers will give 16TQ off the line thus allowing us to hang with mustang gt's
I will be able to add a Y-pipe with these headers too
The fact is headers will do basically what all other bolt-ons do: Add high end power. No off the line power will be added, and there will be no "jolting back into the seat" from a stoplight with these applied.
Re: Herers a pic of the OBX headers
I really hope thet make somthing that works.
Yes.
Heres a few pics of my old PPC headers from NZ.
Yes.
thanks emax...
Re: Where is the link for OBX
Originally posted by MarcGXE95
Are the headers ceramic coated, crome, polished stainless, what are the runner diameters, what is the collector dia, what type of flanges are used? Am I done yet
http://www.midnightmotorsports.net
Sorry guys, but those aren't headers for any Maxima unless it is RWD. Take a good long hard look at the headers. Look how they're offset and how the O2 bung is placed at the end of the collector. Those are NA 300Z headers if anything. There's no way those headers would bolt up to any factory or aftermarket y-pipe on a FWD Maxima. Unfortunately, there's no way headers will be effective with our Y-pipes. The primaries are forced to be way to short.
I guess I don't understand the quest for headers. Ethan has already proved that headers aren't worth much. There's been a lot of bad mouthing concerning the performance of the NZ headers. IMO, the NZ headers are of a VERY good design. Ethan proved that the stock manifolds are more than adequate for our motors. Sometimes engineers do get it right the first time. It's the Y-pipe that's the problem.
Dave
Dave
Originally posted by Lordrandall
***Thinking back to the last time Ewok Dynod headers...***
Originally posted by MaximaZero
true. if there were little to no gain from those NZ headers, why would the OBXs perform significantly better?
no way these will fit a Maxima!!! heres a pic of the 300zx headers--->
Dave
Dave
Ethan, perhaps the 4th gen exhaust manifolds will fit the 2k2? From what I could tell from the FSM the heads are the same dimensions, and I'm banking on it for a future motor swap. Check and see if the exhaust manifold gaskets are the same part number, it their not maybe ask if you can look at them, you may need to open the ports on the on the 4th gen exhaust manifolds, but I bet they bolt up the same. I have a spare set of 4th gen exhaust manifolds I would lend you to check out, and if they work we can work somthing out after tha fact. You should have a spare set from the header install you did on your 4th gen? Leme know...
