oh man :(
Old May 28, 2002 | 11:56 AM
Jamsan's Avatar
oh man :(
i was showin a friend today my intake and stuff....frickin, 2 of the nuts and washers were not on ....they musta came off from all the wear and tear....im hoping this was my problem with bad fuel mileage...also what could be any side effects from this? ...when i accelerated, the filter popped back, and exposed the MAF to everything (well about 1/4 of the maf)
Old May 28, 2002 | 12:28 PM
global_threat's Avatar
wow, you must have done a very bad job installing it
I've had my intake on for over two years and I still have all my original bolts in place
Old May 28, 2002 | 12:40 PM
DeRaNgEd's Avatar
One word for you..... LOCTITE!
Old May 28, 2002 | 01:21 PM
Jamsan's Avatar
first time i had put it on tight, then when i was installing the upper DIY intake, i had taken the filter off to clean it, didnt put it back on tooo tite :\
no one knows how much damage coulda been caused?
Old May 28, 2002 | 05:51 PM
DeRaNgEd's Avatar
As long as the screws didn't fall in you should be OK. Pull the intake off and look in at the MAF and if you can, look at the TB too. See if there is any **** in there like leaves or dirt. Clean it out to be spotless.
It wouldn't hurt to change your oil and oil filter.
But I'm paranoid. You can just check if there is anything inside and put it back together.
NERDJUSTBNME
Sep 30, 2015 03:20 PM
NissLover
Aug 22, 2015 10:26 AM
Maxboy23
Aug 21, 2015 11:02 AM
