60,000 Mile Tune-Up
60,000 Mile Tune Up
Ok, I'm doing my 60,000 Mile maitenence.
Oil change with Mobil 1 (I know Amsoil is better
) and Nissan oil filter, with a new little copper gasket.
Replace fuel filter with 300ZX filter (does it matter what year?)
Try the poor mans intake, if im not happy, new OEM filter.
Coolant flush and fill
ATF change (do i need to do anything else, and can anyone recommend a brand thats not stupid expensive)
I'm also considering replacing the belts, they make a very quiet squeal sometimes when its cold, do you think its neccasary.
) and Nissan oil filter, with a new little copper gasket.Replace fuel filter with 300ZX filter (does it matter what year?)
Originally posted by Sarah99GXE
My mechanic wouldn't change my spark plugs at my 60K service...he said they were some kind of platinum spark plug and were still working excellent.....
Re: 60,000 Mile Tune-Up
Originally posted by Tactics
I noticed the 300zx fuel filter, does it increase flow, or was it just designed better?
What he said...
I don't have ABS and I haven't put it in yet, but I will tomorrow, so ill tell you how it is.
Damn, I was pricing everything and I completely forgot the spark plugs. Bye, bye $60.
What he said...
http://www.ngkwholesale.com/
Got 6 shipped for 48 bucks. Shop around.
What he said...
What he said...
You'll have to gap them yourself and change them at least every 30k miles...but they're a hell of a lot cheeper.
Usually when they squeal they are loose so you could check the deflection and if they are ok, probably cheap insurance to change them anyway.
Here's some help
http://integra.vtec.net/geeser/megamax/60k_service.html
Fuel filter is a PITA! It's not really a hard thing to do, it's just hard getting your hands in there and getting the F-in hoses off the top and bottom.
I just finished the fuel filter. I found it much easier to get to after i removed the intake. Then i just pried at the bottom of the hoses with a flat tip while i pulled the hose away from the filter. Once you get the hose to move a little try twisting the filter also, that helps.
A 300ZX fuel filter is about twice the size, but it fits in the old bracket perfectly. I think it was like a dollar more then the Max filter, but it should last a while longer.
All in all it wasnt half as hard as i expected.
Does anyone know the proper deflection for the belts, I dont want to make my new belts the same as the old ones since they might be off a bit.
Turbonut
46
Oct 21, 2015 08:28 PM
JoshG
51
Sep 21, 2015 10:41 PM
zzznightmarezz
Sep 21, 2015 06:32 PM
hntwhttail
Sep 12, 2015 03:43 PM
