Installed AE Shifter, but...
I installed my AE shifter last night and finished it up this morning. It's a high quality shifter, looks very nice, but... it doesn't fit correctly. It looks like modifications to the internal metal shift rod or some other modification is required. There's approx. an inch gap between the shifter and base. Also, the holes don't line up. There are 2 ways to connect the wires.
Option 1: Take apart the center console and replace the 2 white wires with the 2 new white wires.
Option 2: Yank up on the old shifter and cut the 2 white wires and then splice on the 2 new white wires.
Either way will work. I tried option one. I took off the entire center console. (See pictures) If you follow the white wires (about 1 foot long) you meet up with a wire connector. I couldn't unhook the wires from the connector. You may be able to do this with the correct tool.
After a few hours of ****ering around with this, I put my old shifter back on. I'm not sure how I will handle the reinstall. There are a few solutions. I'll step aside and let someone more knowledgable than myself take a stab at it.
Pictures: http://members.nbci.com/vqlover/aeshifter/
I'll upload a few more soon.
[Edited by Paul2kGXE on 12-02-2000 at 06:21 PM]
What do you mean it doesnt' fit correctly, is it loose when installed or the gap is pretty noticeable?????
How about the size and height of the AE shifter, is it shorter or smaller than the stock one???
thanks for the info
tim
It's loose, since the holes don't match up. And their is a gap that is noticeable. The AE shifter is shorter, which causes a problem with the internal rod that it slides over. See my pictures.
thanks for the info
tim [/I]
thanks for the info
tim [/I]
I looked at your pictures and I think I understand what you are saying as to why it does not fit; however, it is a little difficult since I have never taken mine apart.
For clarity, can you summarize what else is needed to make it work as if it came on the car to begin with? Is more than the shifter needed?
I think more internal parts are needed. Or the metal rod needs to be cut down. I suspect the internal rod on the AE is shorter.
That sux, i was the about to order AE shifter **** next week from Dave!!!!!!!what should i do?
How about the pedal sets, will it fit ????i heard someone mentioned on this forum ealier that it is pretty hard to get it to fit also????
So, if without modification to the metal rod, the shifter wont' fit on 2k max rite????
The shifter is a problem, though and your best bet is probably to wait and see what happens before you order.
Originally posted by blackY2Kmax
That was me about the pedal, but it definitely fits - it jsut takes some work. The aluminum makes it less flexible and not very easy to get on, but WD-40 makes it very simple.
How about the gas pedal, is it removeable like the brake one? it seems to me it's not??
[/I]
Any fix to the problem????
My girlfriend just ordered the AE
sills and the shifter for my B-day.
Got the sills the other day. Put them
on in less then 5 mins. Piece of cake.
I was under the impression that the
shifter would be a bit more difficult
to install. Like the 2 screws, and some
yanking, but I did not think there would
be such problems. It should be here MON.
or TUES. What do I do? When I spoke to
Dave B, he told me there shouldn't be
any problem with the installation, since
all the surrounding part numbers matched
between the 2000 and 2001. If anyone
has any suggestions, please post them,
because I am going to be screwed when
the shifter comes, which won't be long,
PLEASE HELP!!!!!
Thanks,
Howie
PLEASE HELP!!!!!
Thanks,
Howie
Re: Any fix to the problem????
PLEASE HELP!!!!!
Thanks,
Howie
PLEASE HELP!!!!!
Thanks,
Howie
That is odd, if all the surrounding parts are the same for 2k and 2k1, how come we have troubles installing the shifter? Someone wanna call up Dave and tell him to talk to his Techinician?????
Tim
Re: Re: Any fix to the problem????
I don't know if it makes a difference or not, but I have a GXE. Also, there's a chance I did something wrong. I think I did everything correctly though. I hope someone proves me wrong.
Tim
PLEASE HELP!!!!!
Thanks,
Howie
PLEASE HELP!!!!!
Thanks,
Howie
Tim
Hey guys- I must admit I'm pretty perplexed, too. I double checked the part #'s for everything associated with the shifter, and everything's the same for all 2001/01s regardless of production date or trim level. One of our service advisors has a 2k SE, we're going to have one our techs install one on it & get to the bottom of this! As soon as we figure it out, I'll post & let everyone know!
Regards, David Burnette, South Point Nissan
Thanks!!!
Dave
Thanks a million. Look forward to the results. The shifter is really nice looking. I hope I can use it. I notice that the new shifter is about 2 inches shorter overall. Thanks for taking initiative on finding these AE parts. The mats and sills are a no-brainer. Hopefully the shifter works out too.
Nothing yet on the AE shifter Huh?
This is not really a problem for me since my
AE shifter has been held up (sitting) in Texas
since DEC 1. Trying to track it for the past few
days and it has not moved. It is just sitting there.
Called UPS they said they cant do anything till
the estimated receive date has expired. Which
is Dec. 7 That is how long it takes ground service
to get from Texas to New York. That SUX.
If it does not move by the 8th I am going to GO
OFF ON UPS. Dave gets it out quick and they take
forever. Then again I could not do much if I had
it till this is resolved anyway.
Dave looking forward to your post on the
resolution to this problem.
Hey guys- The AE shifter assembly is still on back-order, the moment it comes in, I'll rip it apart & try to figure out what it's going to take. Thanks for everyone's patience! -David Burnette, South Point Nissan
Dave... I worked on mine again yesterday. I shaved some of the plastic off the black internal button piece. It made the white stalk piece fit, but I still had a problem with working the button. I'm very close to making this work. I'm not the most savy mechanic, so I'll sit tight and see if someone else can figure it out.
How much and where can I order it? NISSAN only?
I have finally come across some dough..which means that I can finally start adding some stuff to my max. Installed some piaa lamps, and on the way to the dealer today to have them check out my auto tranny to get the module changed, saw this AE shifter. I really like it...where can I go about ordering it? Nissan, or are you people ordering them from someplace else? Also, I don't feel like messing around with my car, if I order at NISSAN, can they install it also? Thanks a million for any help!
Re: How much and where can I order it? NISSAN only?
Mar 12, 2020 12:06 AM
ef9
Sep 10, 2015 10:35 PM
Violator
Sep 9, 2015 10:14 AM
