how do you find out what your keypad code is?
Old Jun 13, 2002 | 09:20 AM
Justin95SE's Avatar
my girlfriend got a 93 but doesnt know the code, is there a trick to figure this out? also, her antennae doesnt go down, is it too late for it or can that be remedied?
Old Jun 13, 2002 | 09:22 AM
Matt93SE's Avatar
STFU n00b!
FAQ you.
read the FAQ pages in the stickies above. (the keypad code info is also in the MAx owner's manual).
Kalebs and possibly craig's FAQ pages talk about the keypad.
if you can hear the antenna motor running and the mast doesn't move, then it's time for a new mast.
Old Jun 13, 2002 | 09:25 AM
Terry28's Avatar
Re: how do you find out what your keypad code is?
http://forums.maxima.org/showthread....ht=keypad+code hope that help.. MAxima rocks !!
Old Jun 13, 2002 | 09:27 AM
Terry28's Avatar
or you can go to the dealer and let them do it.. they did mine for free. Maxima rocks!!
Old Jun 13, 2002 | 09:29 AM
Freaknificent's Avatar
well.....most would tell you to search but its hard to find teh answer so i'll just help ya out cuz i had teh same problem....
first get a flashlight
next go to the passenger side door and put the seat as far back as you can.....
nest on your back looking up under the glove compartment box you'll see a brass colored box which i think is the door security box system.....whatever.....its way under there toward the door side of the passenger side of the car.....if you dun see flash that light around to get a glimpse of it
look for the code starting with S....this is the master code
now yell at ur girlfriend who i hope has a pen and paper ready, the code after the S
now get out of the car close all the door and lock em.
hit the St/cl button followed by the master code....
once you put these in you'll here a prolonged beep and this is when you enter the code you like i believe it can be 5 - 7 numbers but from what i hear it can't be the same numbers in a row (E.G 909xxx)
after you enter the code you like hit ST/Cl and all the door should open....
hit win to put down the windows and trk for the trunk to open....
i believe this is all correct, if not Private message me and i'll be happy to give ya a hand
Old Jun 13, 2002 | 10:03 AM
battleminnow's Avatar
Actually it's four numbers, but the rest is right.
Pete
Old Jun 13, 2002 | 12:30 PM
Shadow1198's Avatar
Large Member
Hey Matt93se, I'm lovin' that new sig pic of yours! I don't completely remember but I thought there is a way to erase the code and then input a new one by putting it in 3 times.
Old Jun 13, 2002 | 12:40 PM
thebull's Avatar
go to my web site in the faq section
Old Jun 13, 2002 | 12:58 PM
MaxManMo420's Avatar
what maximas have a code pad?
Old Jun 13, 2002 | 01:15 PM
«§»Craig B«§»'s Avatar
all 3rd gen GXEs, no SEs have them
and no, it's not a simple swap to add them in
Old Jun 13, 2002 | 01:18 PM
why would i want them????????
Old Jun 13, 2002 | 02:27 PM
drsprite's Avatar
Don't do what I did.... Went to the dealer and paid $30, for 10 seconds of work
Old Jun 13, 2002 | 09:07 PM
Pete
eh......close enough
Old Mar 6, 2007 | 06:35 AM
produserpaul's Avatar
Thanks alot Freaknificent and thebull your instructions worked like a charm.
How tough is it to install keyless entry system?
Old Mar 7, 2007 | 12:29 PM
Chris Gregg's Avatar
Get Off My Lawn
Keyless entry is a peice of cake. You just need an aftermarket alarm system with lock/unlock feature or a keyless entry system. Run two wires from the aftermarket brain to the driver's door and tap into the lock and unlock wires for the actuator. This will subsequently lock/unlock all doors at the same time with just these two wires. You will want to verify the output of the door lock/unlock so you don't short anything out. If I recall, it utilizes a negative signal.
Old Mar 8, 2007 | 09:05 PM
ninjasword71's Avatar
I read the tutorial and printed the proceedure, went out at night in my pj's and a flashlight. The code was just were you said it was. Thankyou so much. Not sure when I need it though...maybe if the locks are frozen or in the dark so I dont scratch the door with the key. But hey it works! Nissan suggested I install a new system.
Old Mar 9, 2007 | 03:39 AM
the stock keypad was pretty nifty, it came on handy so many times. never afraid to lock the keys in the car, could access the trunk no matter what... i actually miss it
Old Mar 9, 2007 | 10:38 AM
My new code works great just doesnt lock the doors when all doors, trunk and doors are closed, just beeps. All the other functions work just not lock.
Old Mar 10, 2007 | 02:30 AM
Burn MF Burn's Avatar
the keypad is the **** man no need to carry your keys around with you.
as for as the keypad code just takeit to your dealer and they will reset it for you no problem.
Old Mar 10, 2007 | 09:06 AM
Caidwen's Avatar
I found and set my keypad it unlocks evry door but not trunk like it's suposed to. Any idea how I can fix that?
Old Mar 10, 2007 | 09:32 PM
saxytothemaxima's Avatar
You prob have a wiring problem. Does it light up or beep after you put in the number then press the trunk button?
Yeah, the keyless entry kicks major bootah. haha. I love it.
Old Mar 13, 2007 | 08:17 AM
Caidwen's Avatar
[QUOTE=saxytothemaxima]You prob have a wiring problem. Does it light up or beep after you put in the number then press the trunk button?
No it dosen't light up but it does beep .
Old Apr 4, 2007 | 06:46 AM
evildoughboi's Avatar
about that antennae, you can just use wd40 to rigorous clean it (if it still extends and u can hear the motor running). since you prob have not in a long time, stuff will get on in the inside of the housing, which is a real pain to clear out (just thru forcing it up and down). after you clean it, i use a bike lubricant to prevent too much dust from collecting (it'll last a month or two before ur next cleaning). however, what i figured out this winter was that bike lubricant (i got the wax kind so maybe different for others) is that it'll freeze at around 30F so i had to switch back to wd40 during the winter. i guess you could find bike (chain) lubricant that works well in the cold, but not sure if they sell 'em since most ppl wont ride when its 30F outside.
im still trying to see if its possible to clean the inside of the antennae. it might be needed if the above steps dont work for you (and from what i've heard from my brother whose been on the forums for a while, its a pretty common problem)
mvm062
Nov 30, 2020 09:00 AM
markevans999
Sep 10, 2015 04:29 PM
dcam0326
Sep 7, 2015 07:26 AM
