How to install two Alpine Type R Subwoofers
i need to know How to install two Alpine Type R Subwoofers
OK,
I have a 2000 Nissan GLE w/ Bose system. I was looking for an easy was to install these two 12 inch subwoofers. I have a box for now and will install custom boxes later. I also have a new amp that needs to be hooked up. I do not want to buy a new head unit and i would love to not remove the dash and everything to see if there is a preamp out. What is the deal with the 20 + wires runing into the stock amp? Is there wiring that i can tap off of to run to my new amp? Is there a way to do that and keep the other 6" sub still attached. What i want to be able to do is have this for more bass when wanted, but be able to turn it off and still have the little sub on the rear deck for when the mrs is driving????????? Any Help would be appreciated
Re: i need to know How to install two Alpine Type R Subwoofers
ignore the wires goin in and out of the amp.. The sub is self amplified... Tap into the black and white wire coming out of the amp and going to the sub. These are your signal wires... Use the green wire as your remote turn on signal..
Adam
Adam
Thanks for the reply, but i do not know much about this stuff, i do know that there is a rca plug in (R and L) and 4 wire spots, L-, L+, R-, R+, and the power, ground, and remote. What do i do?
i have a diagra of the amp but i cannot paste it to one of these threads.
1. An amp with high level inputs
OR
2. A line-out converter ($20 or so....)- this converts the 4 wires (+L, -L, +R, -R) into a pair of RCA jacks.
If I were you, I would pull the 15 amp fuse under the hood before you start just to be safe......
Originally posted by asu174
You can't hack into the Bose system without:
OR
OR
Adam
What do you do with the black and white wires. Are they a left and right or what are they, what would i use them as when i plug them into my new amp? Are the a Right and A left like an rca plug, or are they Right +, Right - or , L-, L+
Adam
Originally posted by 2000MaximaSE
they are a positive and negative.
Adam
Adam
Then get an rca splitter and hook it to the rca cable u just made.
Adam
Adam
dvcamp
Sep 18, 2015 10:17 AM
