STOCK 2k2 auto 14.6 @ 93
page 5 of homepage is my timeslip already posted once but i am very happy with my first showing at the track.
regular tire pressure
spare and jack in trunk
window down lol
window down lol
Re: STOCK 2k2 auto 14.6 @ 93
window down lol
window down lol
Re: Re: STOCK 2k2 auto 14.6 @ 93
Originally posted by Majisto
Whoa nice! I'm getting a 2k2 Auto soon, and I was getting worried I should try and find a 6-Speed. This time makes me feel a little bit better knowing that the automagic has some power behind it
can't wait for the y-pipe and intake maybe i will hit low 14's on street tires and thinking about getting 15's with slicks and i will be the first 2k2 auto in the 13's
Re: Re: Re: Re: STOCK 2k2 auto 14.6 @ 93
Originally posted by 2k2max
Dude! 14.6 without an intake??? That is sweeeet.
I've seen some post of 14.8 with intake. I'm itching to go to the track. You have defineatly given me some inspirations!!
I just need a "good traction day"
Re: Re: Re: Re: Re: STOCK 2k2 auto 14.6 @ 93
Originally posted by mattattax
me
me
Some say you loose low end power. Most say you gain power. After reading TruBlu2k2 run a 14.6 without an intake, I am interested in seeing what he would do with an intake. You would assume he would gain, but like I saw in some other post (no disrespect mattatax) they are running 14.8's
I understand that there are other conditions involved, like track quality, temperatures, and such.
I guess there may be too many factors to consider. If so, it would almost be pointless to argue anything.
Sorry if OT.
Re: Re: Re: Re: Re: Re: STOCK 2k2 auto 14.6 @ 93
well i will be getting a UDP and injen intake next month so we will see when i test my car with those mods
I wish I had the time to "research" the intake debate.
Sorry if OT.
Sorry if OT.
Re: How did you do that!?
Originally posted by soopermax02
Out of curiousity how did you shift? Manually (I suspect) or did you just put it into drive and let it take over?
Now I really must get the track!
trublu2k2, I think you've started something here..
ease on it from the launch to about 2500 before you floor it manually shift first at 6000 and do the same in second to third. keep your car cool as possible and try to have as little gas as possible although i had almost a 1/2 tank. come to think about it i don't even remember brake torqueing. ask some others cause it was my first time ever at the track
Originally posted by Virus
Please explain everything you did to achieve this time. I'm going to be going to the track next week with my auto to race a friend and I definately need help to beat him.
noi meant ease on the throttle when the tree is green or on the third yellow just don't floor it right away or you will spin like crazy. i'm not really sure what exactly rpm i floored it on but i think it was near 2500 before i went WOT
When you say "ease on it", do you mean to keep the brake pressed down and push on the gas until 2500 rpms and then release?
don't know i guess autos are just a lot more consistent than manuals on the track but i think thats a known fact but i am going this friday to see if i might can get to 94 trap but in a few weeks i will have the injen intake and UDP and possibly a y pipe if they decide to test fit it and put it into production then it might be 13's but thats high hopes but possible
Originally posted by kloogy
Awesome time, but we all seem to be trapping the same speed in the auto's, ..... WTF ??
Great Showing!
TruBlu,
As I said before - Excellent time!
Showing those 6spds that we can be comfortable in the Raleigh and Charlotte bumper-to-bumper (without replacing a clutch each 10K) and still pop off nice 14's.
Going to try to make it this Fri. I'll PM you when I know for sure.
Sorry you got rained out last Fri. but we really needed the wet.
Shaydz
Shaydz
well i went on 7/5 and couldn't break a 14.9 but it was 99 outside and the humidity was well over 90% cause it was so sticky outside
. i think i will wait till about sept or october before i run again
blubyu2K2,
Give this formula a try and you will know what you will run in different weather conditions. Did you know what your barometer was on that run?
http://xs-fx.com/da/ws.htm
blubyu2k2,
I think it is working now. Give it a try.
I ran it with on your 14.6 run and used 91 degrees and 90% humidity. At 70 degrees and 50% humidity you would have ran a 14.26. Quite a difference.
Original Conditions:
Temp: 91
Humidity: 90
Barometric Pressure: 30.00
Density Altitude: 2,555
Original results:
ET: 14.6
MPH: 93
Submitted conditions:
Temperature: 70
Humidity: 50
Barometric pressure: 30.00
Density Altitude: 783
Corrected results:
(What you would have run under the submitted conditions)
Corrected ET =14.26
Corrected MPH =95.33
Temp: 91
Humidity: 90
Original results:
ET: 14.6
MPH: 93
Temperature: 70
Humidity: 50
Corrected results:
Corrected ET =14.26
i think we can hit 14.40s to 14.50's with a stock 2k2 auto if the weather is cooler out!! i ran 14.70 at two different tracks with 90+ temps outside. (even with bald tires!!) i had traction control off and was manually shifting too.
Good runs dude! I've never driven an auto, but I certainly respect them now. I'd actually like to race a 2K2 auto at the track, but sadly, I'm usually the only 5th gen there.
Weather, IMO, is THE most important factor when racing. When I was bone stock (removed spare and ran 28psi in front tires) I ran a 14.230@99.23mph. The temp was around 65 degrees I think and humidity was quite low. When I had an intake and lightweight wheels (SSR Competitions 17" @ 14.3lbs each) I ran 14.3 to 14.4 all day. The temp was like 94 degrees with humidity in the 90s as well. I'm just itching for the first decent Sunday afternoon and hope to hit 13s with an intake.
well i hope to get about 14.2 in 60 degree weather and low humidity once I get my injen and UDP installed
Originally posted by blubyu2k2
well late october will most likely be my next run
and will finally have some performance mods
-Nate
yup too hot for optimal results but I do have my UDP. My intake is on order now so just gonna have to wait bro.
Originally posted by nforg
I saw earlier in the thread, 'in a month I'll have ....., and we'll see how I do' and that was in late June..... It's early August I know, but are we gonna have to wait till October to see the difference now??? ....I'm just impatient (sorry).
-Nate
-Nate
sorry to inform you but I just installed my UDP today so I guess that makes me stock again doesn't it. I would no post this saying I was stock if I had any engine mods at all. I had no mods to my car at all when the 14.6 was run i was COMPLETELY STOCK now you can keep your $.02 for future mods
Originally posted by gt1380a
congrats. but having a UDP does not make you stock anymore. my $.02
