Plug wires, OEM or aftermarket
Old Jun 25, 2002 | 11:19 AM
Linkage23's Avatar
I am giving my Maxima a tune up my slef and I am curious what plug wires are recommended. I have a '95 GXE and I am hearing that the Maxima fires hot, so should I replace with better conducting wires? Thanks.
Old Jun 25, 2002 | 11:39 AM
sbslacker's Avatar
Re: Plug wires, OEM or aftermarket
Plug wires???
Maximas have a tendency to run rich from the factory...mine did.
Old Jun 25, 2002 | 11:50 AM
Chuck Vaughan's Avatar
Re: Re: Plug wires, OEM or aftermarket
The 95 - up Maxima engine doesn't have plug wires in the traditional sense. It also doesn't have a distributor. Each sparkplug is fired by an individual coil pack that is plugged into the engine wiring harness and controlled by the engine computer. So, there are no plug wires to replace, which will save you a couple of bucks. The bad news is the plugs themselves are expensive, about $11 - $13 each. Don't try to cheap out and buy Bosch platinums or somehting like that, do a search and you'll see the consensus here is that the OEM plugs, NGK Platiums, are the only way to go.
Old Jun 25, 2002 | 11:53 AM
njmaxseltd's Avatar
NO WIRES!!!
There are no spark plug wires on the Maxima VQ motor. The setup is direct coil on plug. Use the OEM NGK Platinum plugs when you tune up your car.
Tune up should include:
Plugs
Air Filter
PCV Valve
Gas Filter
Clean Throttle body
Transmission, engine oil and coolant change - Depends on interval
Inspect belts, hoses, tires, brakes, windows, wash, wax, detail and refill washer fluid.
Enjoy The Ride!
Old Jun 25, 2002 | 11:58 AM
Jime's Avatar
Actually you can use the copper version of the NGK plugs and they work just as well, just last half as long, but for a couple of bucks a pop its worth using them. Plus if you are using nitrous you have to use them. The spark from the platinum's is not as intense as the copper plugs and the extra pressure etc from the nitrous has a tendency to blow out the spark. I know some people are still using platinum for juice but you are taking a risk.
Old Jun 25, 2002 | 12:01 PM
mzmtg's Avatar
Minister of Silly Walks
Besure to replace your timing belt, distributor cap and plug wires at the same time.
Old Jun 25, 2002 | 12:08 PM
Jime's Avatar
Ur just plain bad.
wyobbagy
Jan 3, 2023 12:03 PM
The Frye
Sep 2, 2021 11:03 AM
9aj9
Apr 5, 2020 12:11 AM
aminus21
Sep 12, 2015 04:53 PM
