Starting Problems, due to aftermarket alarm system?
Old Jul 6, 2002 | 05:02 PM
JMunaretto's Avatar
G'Day!
My 92 SE has increasingly had problems starting where the starter motor doesn't even attempt to ignite. I bought this car used a few years ago, and there's a small chip (its only strips of metal to pass current essentially) that plugs into a slot underneath the driver side dash. It's called ProLock, and the car cannot be started when the card is taken out. Now the car won't even start with it in, and there's no difference in the attempts to start the car with/without the chip, so I'm figuring that this crappy security device is the culprit.
I noticed the device has 6 wires coming out, 4 of which are connected to ground, and then a yellow and red wire which are connected to 2 other wires. If i want to take this system out and turn the car back to normal, what exactly do I have to do? Do the wires attached to the yellow and red wires get connected together?
No worries
Joe
Old Jul 6, 2002 | 05:45 PM
«§»Craig B«§»'s Avatar
Re: Starting Problems, due to aftermarket alarm system?
Originally posted by JMunaretto
G'Day!
No worries
Joe
like you said, you probably just need to reconnect those 2 wires
follow each of them back and you'll probably find them going to each side of the starter wire and if that's the case, just reconnect them
Old Jul 7, 2002 | 12:03 AM
ThurzNite's Avatar
yeah, i too believe that those wires lead to the starter wires, which just need to be connected directly.
Jae
LilVito
Oct 25, 2019 08:12 AM
rbuswell
Nov 17, 2016 04:54 AM
Shock_and_Awe
Aug 23, 2015 01:02 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
PhalC1
Aug 5, 2015 02:36 PM
