14's still elude me! :(
I went to the track Fri. night with very high hopes of getting my N/A auto into the 14's. Although the weather was horrible for racing (about 90 degrees and about 80% humidity) I thought I could at least best my last time of 15.05. The car felt horrible the first race. Like a giant white slug sliding down the strip. It would be the first of 3 horrible runs. Turns out my VI wasn't opening for some reason. I ran the first two runs with it closed and the last run with it tied open. Here's the results:
R/T - 0.6109
60 ft - 2.3754
330 ft - 6.6213
1/8 ET - 10.1258
1/8 MPH - 70.58
1000 ET - 13.1465
1000 MPH - 80.86
1/4 ET - 15.7349
1/4 MPH - 85.53
R/T - 0.8392
60 ft - 2.3516
330 ft - 6.5630
1/8 ET - 10.0493
1/8 MPH - 70.89
1000 ET - 13.1011
1000 MPH - 79.78
1/4 ET - 15.6911
1/4 MPH - 86.93
And with the VI tied open:
R/T - 0.9253
60 ft - 2.4159
330 ft - 6.6744
1/8 ET - 10.1471
1/8 MPH - 71.34
1000 ET - 13.1137
1000 MPH - 82.88
1/4 ET - 15.6212
1/4 MPH - 89.37
Hopefully I can get the vacuum system working correctly for next Fri. night and I'll put some better times down.
R/T - 0.6109
60 ft - 2.3754
330 ft - 6.6213
1/8 ET - 10.1258
1/8 MPH - 70.58
1000 ET - 13.1465
1000 MPH - 80.86
1/4 ET - 15.7349
1/4 MPH - 85.53
R/T - 0.8392
60 ft - 2.3516
330 ft - 6.5630
1/8 ET - 10.0493
1/8 MPH - 70.89
1000 ET - 13.1011
1000 MPH - 79.78
1/4 ET - 15.6911
1/4 MPH - 86.93
R/T - 0.9253
60 ft - 2.4159
330 ft - 6.6744
1/8 ET - 10.1471
1/8 MPH - 71.34
1000 ET - 13.1137
1000 MPH - 82.88
1/4 ET - 15.6212
1/4 MPH - 89.37
A little bit but it's not too bad.
Originally posted by speedemn
Hey man, what launching technique are you using with your car? Is traction a problem for you off the start?
I raced an older Oldmobile Aurora on my last race with the VI open. The car dogs at low RPM's when it's tied open so we were side by side until I hit 5K. Then it pulled away hard. My brother was sitting in the stands and he said he could tell the difference. He said the car looked like it just took off all of the sudden. Before the race, the guy in the Aurora asked me if I had NOS and I said I was N/A and he just kind of smirked.
I'm going to go out on my lunch break and see if I can't figure out what the problem is. I'm hoping it's just my vacuum solenoid switch thingy. I have a couple extra of those.
True.
Originally posted by deezo
That's terrible weather to run under. This is why I'm waiting til the fall to make my runs for a lower time.
im impressed! you pulled off a 15.05 with not many mods. your sig says all u have is intake and exhaust? if this is true all i have to say is y-pipe! you will make 14's no prob then. if u ran a 15.05 without a y-pipe u should run like a 14.8 or so with it
Travis-
I wouldn't "sweat" it too much
It's been WAY too hot here in the Midwest. Up here in Kansas City on Friday it was 95 with 70% humidity and a 110 heat induce. I can only assume it was about the same down in Joplin 150 miles away. At nightime, the temps do drop into the lower 80s, but the humidity skyrockets. You can't expect to run good ETs and mphs in this weather. Don't forget that my best time and mph at your track was a measely 15.0@94mph in similiar hot weather and I've got a 5 speed!!!!!!!!!!
I'm running this Wednesday at KCIR for fun with my "Honda" friends and the weather is going to be deep in the 90s. I doubt I'll get into the 14s. BTW, I still haven't recieved my VI yet.
It looks like your VI did help out in topend MPH and some of your ET even though you weren't using the long runners. It looks to me like the VI netted you nearly 3mphs and put you pretty close to what kind of MPHs you get in much cooler weather. That says a lot. In weather like this, I'm usually .3-.4 and 3+mph slower. Don't sweat it.
Dave
It's been WAY too hot here in the Midwest. Up here in Kansas City on Friday it was 95 with 70% humidity and a 110 heat induce. I can only assume it was about the same down in Joplin 150 miles away. At nightime, the temps do drop into the lower 80s, but the humidity skyrockets. You can't expect to run good ETs and mphs in this weather. Don't forget that my best time and mph at your track was a measely 15.0@94mph in similiar hot weather and I've got a 5 speed!!!!!!!!!!I'm running this Wednesday at KCIR for fun with my "Honda" friends and the weather is going to be deep in the 90s. I doubt I'll get into the 14s. BTW, I still haven't recieved my VI yet.
Dave
My experience http://forums.maxima.org/showthread.php?threadid=131864
Travis-
Are you sure that you've got the Harlan switch on the correct setting? I know when I intially set up my Harlan shift light, I incorrectly set it up for the wrong ignition system and it didn't work. A simple test would be to setup the VI to open at 2000rpm and to have the motor running and open the throttle body with your hand and see if the VI butterflies kick on. Let me know because I will be getting mine soon and I don't want any install hang-ups
Dave
Dave
Originally posted by 1SikMax
I just ran the 1/8 track here and I could not get around 9.9 at 69mph at the end. Ofcourse, it was 85' out with 80% humidity. What I would do for a 1/4 mile track.
I found the problem!
The ground wire on the vacuum solenoid wiggled loose. Took it for a spin yesterday and I can hear it when it opens. Can't wait till Friday
night. Hopefully the temps will be a little cooler.
Dave:
I'll try and come up when you get yours and help you out if you want (now that I finally got mine working
Dave:
Re: I found the problem!
Im anxiously awaiting your result. My VI purchase depends greatly on it. The weather in and around our nation's capital has been awful as well, Im just praying for a cold front. I've had 3 or 4 attempts with different setups at breaking into the 14s but either the weather gets nasty or something out of the ordinary happens (track crash right before Im about to run which closes the track).
My most recent trial yielded a 15.16 @ 80 degrees F.
Kevin Trout
May 19, 2015 11:31 AM
