$%&#*!&&$ Doors locking automatically!?!?!?
Re: $%&#*!&&$ Doors locking automatically!?!?!?
Originally posted by jdog4au
Pull in the garage.
Get out of the car.
Close the door.
ALL DOORS LOCK. WITH KEYS IN IGNITION!!!!
What's the deal?
Thanks,
Jason
Pull in the garage.
Get out of the car.
Close the door.
What's the deal?
Thanks,
Jason
Wow, that's devious. People usually have problems with just the passenger doors locking. There could be problems with the wiring, ie a short occurred, but I'd think you'd notice symptoms more than once.
You were the only one in the car? The only problem I've ever had with my locks was my friends. Most of them have cars with manual locks and feel the need to lock the door as they get out while I'm still grabbing my stereo & wallet, etc. Then they lock me in. No matter how many times I tell them...
(coincidentally, they're amazed every time I unlock the doors before I get to the car)
Re: Re: $%&#*!&&$ Doors locking automatically!?!?!?
It's my wife's car, and I suspected that she was hitting the lock button on the fob. So I took the battery out of it. Still does it (not ALL of the time, about 50%).
How can I check if the switch is loose?
Thanks,
Jason
Thanks,
Jason
doors
Tell me about it!! Just as I was bragging about how this car is BULLETPROOF and IT WILL RUN FOREVER (155,000).
It happens ALL THE TIME... Just me, me and my wife, me, my wife, and kid. Even with the dogs.
I had a grand am gt once that was programmed to do this from the factory. I found out one day when I was going to go through an automatic carwash, and I got out to scrub the wheels......yup, car was even running, with keys in the ignition, and there about 5 cars behind me!!
do you have a after market car alarm? If so they are usually programmed by default to lock keys. They can be re-programmed to not do this behavior. I had this problem on my accord so I went to the manufacturers website and downloaded the docs and reprogrammed it to leave the damm doors open and also turned off auto-arm. hope it helps.
That's strange...
because I CAN'T lock my car with the keys in, and a door open...
I guess I could lock it with the door closed, but, with the door
closed and the keys in the ignition, how the hell does it lock?
have you checked for gremlins?
FLO_BOY
FLO_BOY
Re: That's strange...
FLO_BOY
FLO_BOY
I have a 98 GXE. WhenI got my car I told the dealer I didnt want their security system. The doors never used to lock autmatically. After I got my clifford arrow put in, the doors lock as soon as I put twist the key to ACC (right before the engine cranks). Id recommend you guys check the security system out.. they relays might be flaky.
Hey make sure the security isn't in passive arming mode. That locks all the doors once the ignition is off. It is on a timed relay so you may want to ask the dealership if that is the case. Also I used to work at a car electroinc store and people used to buy cars and never eealize they had the alarm because no key chain but then looked under the dash and sure enough there was one from the previous owner. CHeck it out. Goodluck.
Re: Re: Re: $%&#*!&&$ Doors locking automatically!?!?!?
Thanks,
Jason
Thanks,
Jason
I'm bettin on the switch on one of the front doors too. Even with the key in and the engine on if you manually lock either front door it will lock all 4 doors. You don't even need to lock it all the way, just move the lock lever a liiiittttle forward and it'll lock the rest.
So that's got to be the problem.
Figure out which front door does it. Then pull the door panel off and try to figure out where that sensor/switch is.
-RMB
power locks
You have a short somewhere but lots of luck finding it.
I had a Toyota Celica GTS with every option including power locks and it would lock whenever it took the notion. I could be riding down the road and the power locks would click the locks on and off 3 or 4 times in 10 seconds. Then, it might not lock itself for a month. I never left the keys in that car.
Originally posted by ReichMax97
My car does the same thing sometimes. I will park it in the garage and NOT lock it and come to it the next morning and it will be locked, and I'm like what the hell?
REDinLV
Aug 15, 2024 12:30 AM
magiconthetire
Oct 26, 2015 09:03 PM
Andy29
Sep 29, 2015 05:32 AM
LOL
