Wet kit and VI
Old Nov 22, 2002 | 09:50 AM
Maksim2000's Avatar
Wet kit and VI
I can see the benefits of running a wet kit, the only concern I have left is wheither variable intake manifold on my car will present a problem for running a wet shot. Will there be problems with fuel collecting in the intake manifold due to butterflys ? Don't want the fuel puddle to ignite in the manifold.... that would suck.
Old Nov 22, 2002 | 10:23 AM
Jime's Avatar
Re: Wet kit and VI
You can talk to the NX tech support on this. I have asked and there are many people running VI's on other makes and have no problems whatsoever. The whole concept of the NX WET system is that the nitrous/fuel nozzle atomizes the fuel so well that it is a vapour not a liquid and if it was going to puddle it would do so in the stock manifold because of the much longer runners.
This is a NOS fairy tale because they can't design a wet system that will work properly. They even have it in their manual.
Old Nov 22, 2002 | 12:18 PM
A-Ron Max's Avatar
Ya this is a big concern for me too since I should be getting my VI in Dec. then I wanted to get an NX kit. I am not going to go through w/the nitrous unless I am %100 sure that there won't be any complications, are there any 4th gens out there who have the VI manifold and running NX? One more thing (since I don't have any experience with it yet) would there be any problems having an RPM switch for both the Intake manifold and the nitrous?
Old Nov 22, 2002 | 01:04 PM
SVTTODAMAX's Avatar
Just stick with spec that they "NX" suggest and you can spray until your hair turns grey. Get away from the NX spec and your on your own unless they offer you tech help. they will help to an extent don't expect them to take you serious if your trying to spray a 200shot or something crazy like that on your stock block.
Old Nov 22, 2002 | 02:02 PM
Maksim2000's Avatar
No you can have as many RPM switches as you like (until you start hitting "draw" problems once you add few dosen or so )
Old Nov 23, 2002 | 07:29 AM
ejj's Avatar
ejj
I would have them pull from different sources. IE - each switch reads from a different coil pack, etc.
Old Nov 24, 2002 | 12:26 AM
Shadow's Avatar
Re: Wet kit and VI
I have no idea what would happen with the VI on the Maxima, but my friend has a '00 Integra GSR which comes with a dual stage manifold like the VI. And he just got a DPI kit from NX directly, and they told him to disable the butterflies so they stay open if he's spraying. And on some Honda forums, a wet kit has been known to cause puddling in the manifold due to the fuel collecting under the butterflies. That's not something that a nitrous company can really design around, no matter how good the fuel is atomized, some of it is bound to condense/collect when there are butterflies in the manifold.
Old Nov 24, 2002 | 11:02 AM
96BLUMAX's Avatar
So we can't get the full effect of VI if we want to stick with the NX kit?
Old Nov 24, 2002 | 12:22 PM
mtrai760's Avatar
'Trynna' is not a word
I have a VI and I'm currently doing some in depth research on this subject. I'm taking some close up pictures of the VI manifold, the butterflies, the resonation chamber, etc, and sending them to Nitrous Express to get there opinions on Direct Port and Wet nitrous usage with the VI. I will post my findings when I have the facts.
Old Nov 24, 2002 | 06:44 PM
Shadow's Avatar
Definitely let me know what they say about this. All the info I have applies to Hondas with the VI's, and I'm not familiar enough with the Maxima VI to know if the same applies. And I'm about to swap my NOS kit for a NX wet kit, and get the VI.
Old Nov 25, 2002 | 03:11 PM
SuDZ's Avatar
What kind of kit does MardiGrasMax run with his nitrous and VI setup?
SuDZ
Old Nov 25, 2002 | 04:54 PM
mtrai760's Avatar
He runs a NOS dry kit.
SuDZ
Old Nov 25, 2002 | 09:00 PM
gould2000's Avatar
Why would the butterflys make a difference if you......
If you mount the nozzles cleser to the lower intake manifold, aren't they far enough after the butterflies that it wouldn't be an issue. I am working on the NX direct port kit, and i mounted my nozzles pretty damn close to the end of the individual runners. The nozzles are pretty damn low, and the thing hits really hard for only a 60 shot.
Old Nov 25, 2002 | 09:19 PM
Maksim2000's Avatar
Re: Why would the butterflys make a difference if you......
I was kind of wondering the same thing about direct port, wet kit however sprays before trottle body so I can see how it can possibly get affected by the VI.
Old Nov 26, 2002 | 07:19 AM
gould2000's Avatar
Re: Re: Why would the butterflys make a difference if you......
I hear ya, I was just referring to the direct port on a MEVI. A wet kit would be interesting to see. NX's advice would probably be the best to follow for a straight wet kit. But direct port, you should be fine.
Old Nov 26, 2002 | 10:53 AM
Jime's Avatar
Re: Re: Wet kit and VI
We have GSR's and h22's in the SR-V 2.2L VTEC motor with Variable Intakes all running the wet NX kit with absolutely no problem and no modification to the butterflies either.
Not sure who told him that but the NX
tech support has never heard of it either. Especially with a DP kit the fuel doesn't even go through the throttle body.
Old Nov 26, 2002 | 04:33 PM
XXXL Cracker's Avatar
Re: Re: Re: Wet kit and VI
Jime:
Does this have a butterfly system similar to the MEVI? I am more than willing to take the plunge. I spoke to NX tech support and they could not forsee any problems.
I have one more call to make and then I will be installing. With the amount of manifold vacuum present under WOT, the only time there could maybe be a problem would be right at switch over. I am going to be using a MSD window switch and there is the possibility of setting the pills in conjunction with the normal RPM switch so that everything happens at the same time.
I really wish I had taken pictures of my VI in detail prior to installing it.
If anyone has any pics please post or email me.
Dave
Old Nov 26, 2002 | 06:07 PM
Jime's Avatar
Re: Re: Re: Re: Wet kit and VI
Originally posted by dlicari
Jime:
Dave
Dave, yes they both those engines vi's with butterfly valves. I was talking to a friend today who owns a performance shop that builds race engines, installs turbos etc and he said he has installed the NX wet kit on a few variable intake Honda engines and they work great and a couple have been in operation for over a year.
Old Nov 26, 2002 | 06:08 PM
Maksim2000's Avatar
Dave
There are some here:
http://www.vanillaice.com/webmasters/hype/mrc/mevi2.htm
You can use couple of windows switches to make sure you don't spray during switchover... (one switch to activate from starting RPM to slightly before switchover RPM and then another one to activate from swithcover RPM to the redline) it doesn't take that long to switch over though, so I'm not sure if it is really nescessary to stop spraying.
Old Nov 26, 2002 | 08:09 PM
Re: Re: Re: Re: Re: Wet kit and VI
Thanks........
D
Old Nov 27, 2002 | 10:43 AM
SuDZ's Avatar
Dyno runs show a .1 -.2 second switchover time.
SuDZ
Old Dec 4, 2002 | 06:41 PM
Iron Lung's Avatar
I wonder if (using a dry kit) it would be benefical(power wise) to run with them open?
Old Dec 5, 2002 | 02:32 PM
buss95max's Avatar
disabling the butterflies doesnt make sense, wouldnt they stay close if they are disabled? i know a couple dudes take the butterfly plate out all together, they all say they lose some downlow torque, but their high is end is better. either way im running a direct port wet kit to my h22a w/o any problems.
Apr 16, 2020 05:15 AM
Kyle Lee Cleveland
Sep 28, 2015 07:58 AM
Pied
Sep 26, 2015 03:29 PM
