difference in ET between juice and w/o
Old Dec 16, 2002 | 05:28 PM
luckee2bhere's Avatar
Does anyone with like a 50 or 70 shot know what the difference in quarter mile ET is with the spray and without? My friend told me my car will be noticeably slower than it is now when I am not spraying.
How risky is this stuff? sounds like 100 is a big deal but 50 wouldnt be so bad?
Old Dec 16, 2002 | 05:35 PM
mtrai760's Avatar
'Trynna' is not a word
Re: difference in ET between juice and w/o
NA auto: 15.3 50 shot auto: 14.4
Old Dec 16, 2002 | 06:18 PM
Jime's Avatar
It will not be slower than it is now when you are not spraying.
Mine went from 15.7 to 13.6 with a 75 shot. 5 mins between runs, no other changes.
Old Dec 16, 2002 | 09:49 PM
My best 1/4 mile to date is a 14.63 in my '98 5spd. Any idea what a 50 or 75 shot might take off of that?
Also I have 92k miles on my car. How bad is this for your MAX?
Old Dec 17, 2002 | 04:16 AM
Jime's Avatar
Depends on what kit you are using and once you get under the 14 mark you need slicks if you want to get good times, otherwise you just spin or feather the throttle until you get traction which reduces your 1/4 mile time dramatically.
Sure its harder on your car, is it bad? Is too much sex bad for you? Sure if you get carried away. Stick with a 75, installed properly and you will get years of fun out of it.
Old Dec 17, 2002 | 07:02 AM
De Max's Avatar
Mine went from 15.2 to 14.2......50 shot...good place to start...
Old Dec 19, 2002 | 09:49 AM
Synki's Avatar
15.3 N/A and on 50 shot 14.3
This was in a 99 Auto w/ CAI, Y-pipe, VB Mod, and Nitrous.
Old Dec 19, 2002 | 12:26 PM
Aaron's Avatar
Langley AFB Sux
N20 is good..................
Old Dec 20, 2002 | 09:08 PM
JAIMECBR900's Avatar
Traction provided....you will likely see about 1 sec faster with a 75 shot. That is a difference from night to day.
Old Dec 21, 2002 | 12:16 AM
BJJ's Avatar
BJJ
With major traction problems I went from running 14.8-15.0's to 14.3-14.4's, when I got the traction under control I ran 14.1, this is with the NOS 60 shot, my traps also increased to about 99mph vs. 92-93 when I was NA. Hope this helps.
Old Dec 21, 2002 | 06:18 AM
From the front, your car looks like my cars twin!!!
Old Dec 21, 2002 | 08:52 PM
SmoothMax's Avatar
OG
I went from 14.3 to 13.6. Traction isn't a big problem NA, but on the squeeze there's no grip.
Old Dec 27, 2002 | 04:27 PM
DCmax's Avatar
Synki: why did you get rid of your max?
Old Dec 27, 2002 | 05:43 PM
ToYLeT902's Avatar
JET Speed Lab
i guess you need to play with nitrous a lot inorder to get these times? or do you guys use drag radials?
i dont have a window switch, last time i was at the track i armed my system, rolled into 1st, floored 2nd.. my rpms just stayed at 6k, i couldnt grip 2nd at all... i always end up burning out in 2nd
anyhow, my ET went from a best of 94mph N/A to 97mph spining out with a 70shot
Old Dec 28, 2002 | 07:04 AM
You mean your traps went from 94 to 97mph...
Yes, you have to tune your system to get the better times. The best I could manage with a 70 shot was 13.8-13.6 range. It was still not totally tuned, but did run pretty good.
Slicks help traction, but also hurt top end numbers sometimes. My best times were had with street tires. I had decent 60' with the slicks but lost top end mph. Track conditions also make a big diff in traction.
mkaresh
Mar 12, 2018 06:48 PM
doctorpullit
Dec 12, 2015 09:39 AM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
Pied
Sep 26, 2015 03:29 PM
