how do you wire a "spray" switch?
Old Jan 14, 2003 | 08:09 AM
ToYLeT902's Avatar
JET Speed Lab
i dont have a window switch with my set up (too expensive right now) so all i have is an activation switch, then when i go WOT, the nitrous will spray.
With this set up i cant go WOT in 1st and 2nd because i will just burn out, that means if i activate the nitrous i would have to be gentle in 1st/2nd gear...
my question is, how do you go about wirring a second switch, so i can activate the nitrous, go WOT in 1st and 2nd (N/A) then when i shift into 3rd, press another switch to spray the rest of the way?
or is it easier to just turn on the activation switch in 3rd gear and hope it sprays? last time i tried it at the track (but in 2nd) nothing happened... maybe i needed to purge that run?
Old Jan 14, 2003 | 03:52 PM
CalsonicSE's Avatar
You can wire a momentary push button switch INLINE with the arming switch. That's what I did. So basically when you hold down the push button switch, the circuit is completed and it will spray.
Old Jan 14, 2003 | 04:09 PM
ToYLeT902's Avatar
JET Speed Lab
Do you kno where to buy those little red push switch's that you find on the steering wheel, but you can mount them somewhere else?
Old Jan 14, 2003 | 06:07 PM
CalsonicSE's Avatar
SummitRacing.Com or Jegs.Com would have them. Just search for "momentary switch".
Old Jan 15, 2003 | 08:17 AM
Jime's Avatar
I did exactly what CalsonicSE said, wire it in series with the arming switch. I used a motorcross kill switch and a timex velcro watch band. Also a 2 wire trailer plug so I can remove it.
It is mounted on the left side of the steering wheel on the cross bar, so I can still do stuff with my right hand, like shift if I want to etc. Pretty easy to steer and hold the button down at the same time and it gives you maximum control.
Old Jan 15, 2003 | 09:27 AM
ToYLeT902's Avatar
JET Speed Lab
thanks for the idea!
Old Jan 15, 2003 | 10:30 AM
jdmmax's Avatar
hehehehe i made one out of a momentary push button from radio shack, the houseing for the cigarette liter adapter, wire and a sleave thingy. DCMAX has it now.
Old Jan 15, 2003 | 10:33 AM
ToYLeT902's Avatar
JET Speed Lab
anyone think its worth buying a switch panel? or just use the switch holes that come with the car?
Old Jan 16, 2003 | 07:44 AM
JAIMECBR900's Avatar
Why don't you just activate in 3rd gear instead of wiring a F&F switch? You just got a purge valve didn't you? Just purge, nail 1st and 2nd, when you shift to 3rd....activate. It's not that difficult really.
If your system does not come on when you are at WOT in ANY gear when YOU hit the activation switch, there's something wrong. It's simpler IMO than doing the F&F switch. That switch should be left for the more experienced nitrous user, not taking anything away from you, who knows his car/system and can push the button at the right time. Remember, if you wire a push button activation switch, you WILL spray anytime you press the button. If you are at low RPM or bouncing off the limiter and you decide to spray, you WILL do damage to your engine.
Old Jan 16, 2003 | 08:13 AM
Jime's Avatar
Jaime the spray button is just hooked in series with the activation switch so the activation switch has to be on and the WOT switch has to be activated before it will spray with that button. It does not bypass the WOT switch. It actually adds an additonal step but if its on the steering wheel its saves having to reach for a switch.
I would not suggest anyone bypass the WOT switch, even though I do it myself.
Old Jan 16, 2003 | 08:20 AM
So you are basically wiring it, not in lieu of the activation but as an additional inline on/off momentary switch??? When wired that way, does the "standard" activation NOT take place until you press the momentary????
Old Jan 16, 2003 | 08:54 AM
Jime's Avatar
Exactly. It just allows you to control when you want it on from the steering wheel vs having to reach and hit the activation switch, which has to be on anyway for the on/off momentary switch to work.
When they are in series they all have to be on before it completes the circuit.
Old Jan 16, 2003 | 08:58 AM
ToYLeT902's Avatar
JET Speed Lab
i will have to test that out when i get everything up and runing
Old Jan 16, 2003 | 02:11 PM
Then I retract my previous statement. Thank you for the clarification. If wired and installed as you detailed, that would be the easiest and best way to achieve what toylet was after.
gavin68
Sep 18, 2021 12:36 PM
AaronL
Aug 8, 2020 10:31 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
lrb6805
Sep 24, 2015 05:03 PM
