important question
Old Apr 8, 2003 | 02:21 PM
MaXtUneD's Avatar
important question
http://cgi.ebay.com/ebaymotors/ws/eB...category=33740
I was wondering is this would work on my 92 max.
also what does EFI mean..something fuel injected??
Old Apr 8, 2003 | 02:32 PM
metallic97gxe's Avatar
Master Will
Re: important question
Electronic Fuel Injection
Old Apr 8, 2003 | 02:34 PM
Jeff92se's Avatar
I'm needing a caw
Important question. If you don't know what EFI stands for, do you think you want to handle installing/using a Nitrous kit?
Old Apr 8, 2003 | 04:07 PM
MaXtUneD's Avatar
i know basically all the information i needed..i knew it standed for fuel injection but i just didnt know what the "E" standed for.oh...so is this a good kit to buy??
Old Apr 9, 2003 | 12:19 PM
JAIMECBR900's Avatar
I'm with Jeff on this one, if you had a little trouble with EFI, you probably should research this a little longer before commiting.
To answer your question, yes the NX express is a good system and perfectly suited for the maxima. Question you probably should ask is are you and your car ready for the nitrous?????
Old Apr 9, 2003 | 01:07 PM
MaXtUneD's Avatar
i've been researching for a couple months..i just never read anything about an efi.i just keep on saying fuel injection and all that.i'm ready..its just that i want to get the right kit..
Old Apr 9, 2003 | 01:12 PM
Maybe PM Jim (Jime) and ask him for model numbers for the NX stuff since he likes them and uses them. If you want NOS, the kit needed is the #5124. Those two and maybe ZEX are the three I would recommend.
Are you planning on installing this yourself?
Old Apr 9, 2003 | 01:15 PM
Jime's Avatar
If you are going to boost this is the easiest safest kit going. You can run a 75 shot easy with no other upgrades and there is no tuning involved because it runs on stock fuel pressure. It is truly plug and play, not plug and pray.
Damm I should get a commission from NX.
Old Apr 9, 2003 | 06:39 PM
See what I mean....
Unclejunebug
Apr 2, 2016 05:42 AM
Stagnet04
Oct 11, 2015 08:16 PM
Socalstillen
Sep 26, 2015 12:01 PM
