Dry Kit Fuel Pressure question
Old Apr 25, 2003 | 06:57 AM
ejj's Avatar
ejj
What fuel pressure do you guys with the stock fuel pump get with a .042" bypass jet?
I never installed it with the stock pump...and I know I got way too much with my walbro.
Old Apr 25, 2003 | 11:14 AM
mtrai760's Avatar
'Trynna' is not a word
Re: Dry Kit Fuel Pressure question
Are you talking about on the juice or off? With a stock pump, my fuel pressure didn't change from stock, except when I was spraying. With the Walbarro, I was running 3-5 psi too high, until I installed an aftermarket FPR. Hope this helps.
Old Apr 25, 2003 | 11:19 AM
ejj's Avatar
ejj
Re: Re: Dry Kit Fuel Pressure question
Sorry, I mean while spraying.
Old Apr 25, 2003 | 11:24 AM
mtrai760's Avatar
Re: Re: Re: Dry Kit Fuel Pressure question
Hmm, if I remember right, it was around 60 psi.
Old Apr 25, 2003 | 11:26 AM
ejj's Avatar
ejj
Re: Re: Re: Re: Dry Kit Fuel Pressure question
Thank you.
Old Jun 30, 2003 | 02:52 PM
SonicDust187's Avatar
I just took my car up to redline in 3rd gear NA and my fuel pressure didnt go over 40psi, should I be scared to run my 50 or 75 shot from the NX kit on it?
Old Jul 1, 2003 | 07:10 AM
xHypex's Avatar
I have a list of PSIs on both a stock pump and Walbro for .042, .036, and .034 jets if you want it.
-hype
Old Jul 1, 2003 | 07:18 AM
What I am saying is, is it okay/safe to spary a 75 shot from my wet kit at fuel pressure of 40psi at wot.?
Old Jul 1, 2003 | 07:32 AM
xHypex's Avatar
Probably not. The spec for stock fuel pressure is 43psi at WOT, so even though you're only low 3 psi thats almost 10%.
-hype
Old Jul 1, 2003 | 07:34 AM
Guess I will get a walbro fuel pump instead of the catback I wanted. I want to get the 190 one but I do not know if I need the High Pressure one or not. Can someone give me the part number for it.
Old Sep 20, 2003 | 07:39 PM
teejnut's Avatar
-hype
Can I get that list?
Cotozic
Jun 28, 2017 08:01 PM
umnitza
Sep 1, 2015 01:03 PM
homewrecker
Aug 24, 2015 08:56 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
doobadoo
Aug 15, 2015 06:43 PM
