n2o for MEVI
Old Apr 27, 2003 | 07:30 AM
SLC I30t's Avatar
n2o for MEVI
Ok, I have converted to the MEVI and am having problems mounting the WOT switch on the TB. Any Suggestions? Please.
Old Apr 27, 2003 | 09:33 AM
xHypex's Avatar
http://forums.maxima.org/showthread....hreadid=191248
I had mine mounted, but I broke the bolt/nut while tightening. When I get it installed again I'll take pictures.
-hype
Old Apr 27, 2003 | 10:21 AM
SonicDust187's Avatar
SLC I30t: I was looking at your dyno pull numbers and was wondering what I will dyno at with: NX 75 shot at 950 psi, intake and y pipe? I am also a 5 speed.
Old Apr 27, 2003 | 10:57 AM
SLC I30t's Avatar
Well I hope better numbers than mine. I had really really rich numbers on the a/f mixture. Infact I was off the scale rich. So I've done some stuff to try and keep the Fuel Pressure where it was supposed to be. Once I get this MEVI installed I'm going to do a 3 pull... With out the MEVI, with the MEVI and the last will be with MEVI and n2o. If you are looking for better numbers I would use your stock tires.
Old Apr 27, 2003 | 11:10 AM
xHypex's Avatar
I'm interested to see your results I want to see what kind of numbers you pull, and how the curve looks with the nitrous. I would imagine the optimum activation point may even change (it would probably be lower than 5k).
-hype
Old Apr 27, 2003 | 06:30 PM
Iron Lung's Avatar
Maybe this will help
Or this
Or this
And at any rpm I'm at it seems when I activate the VI while spraying there is a power increase.
Old May 3, 2003 | 08:22 PM
Bags's Avatar
VG Ridah's Biatch Hoe
Have you dyno tested your theroy?
I know with the SC or NA with it open at ANY RPM under 4700 there is a power loss
I ain't knocking YA. Nitrous is the TQ solution. So I am thinking that having it open may help not hurt.
Just curious
Old May 3, 2003 | 09:32 PM
Iron Lung's Avatar
I didn't think to do it when I dynoed, but you can definetly tell the increase. Maybe its better nitrous distribution?
Old May 4, 2003 | 05:16 AM
Bags's Avatar
That may be something for a n2o user to try. I have never thought about this. But It could not hurt.
And thinking about it a little more you may have less TQ BUT more HP when it is open.
And that is the power your feeling..hmmm
Old May 4, 2003 | 05:47 AM
SLC I30t's Avatar
ok I"m getting ready to have my car Dyno'd in 2 weeks. I'm going to get an hour dyno. I can try a few of these theories.
I'm going to do:
1 run base line with VI.
1 run with 85 shot
1 run with vi opening at a lower RPM, but how low?
Old May 4, 2003 | 10:40 AM
xHypex's Avatar
The most thorough combination I can think of would be one or two runs of the following:
NA
1) VI closed
2) VI open
3) VI opening at the crossover point between the two torque curves from 1 and 2
Nitrous
1) VI closed
2) VI open
That would give you the best idea of what's making the most torque at a given rpm (on or off the bottle), and would also minimize things down to 1 independent variable per dyno. That's lots of dynos, but you'd have a wealth of VI NA/nitrous information
-hype
Old May 4, 2003 | 11:15 AM
Bags's Avatar
Live it to someone like hype to come and put LOGIC into this.
BTW see my thread, I do not wanna jack this thread
But you make a VERY valid point. I guess I overlooked that VERY simple in my face idea..lol
Oh well that is why you talk about ideas with others to get a different perspective.
Thank you
litch
123
Jan 4, 2024 07:01 PM
maxprivate
Nov 29, 2017 08:52 AM
maxprivate
Forced Induction
21
Jul 8, 2017 09:48 AM
BkGreen97
Apr 2, 2016 05:47 AM
lrb6805
Sep 30, 2015 08:12 AM
