Double bottle setup
Old Sep 28, 2003 | 03:50 PM
PharoNDmist's Avatar
Double bottle setup
I'm new to the N20 world and was thinking about going with the NX kit. I wanted to know how possible is it to have a 2 bottle setup in the trunk where if one bottle ran out you can activate the seconday bottle from the the cabin without going into the trunk and hooking the 2nd bottle up to the n20 lines?
Thanks in advance
Old Sep 28, 2003 | 03:53 PM
Also what is the biggest bottle NX offers?
Old Sep 28, 2003 | 09:01 PM
anybodyout there?
Old Sep 28, 2003 | 09:20 PM
KiLLeR2002se's Avatar
Eat Naaawwwzzzzz
the biggest ive seen in a car personally is a 20 lb bottle, but im sure there are weird people..
A bigger bottle would be better for you... keep the presure more stable on long shots, only need 1 heater and one opener and takes less room..
Old Sep 29, 2003 | 10:53 AM
cool. Thanks for the response
Old Sep 29, 2003 | 12:00 PM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
You can EASILY Y-connect two bottles together with a connector and some extra line, however I don't see how a 15lb. bottle wouldn't be enough.
I've been looking into Y-connecting two 5lb. bottles, but that's for stealth purposes.
Old Sep 29, 2003 | 12:29 PM
jdmmax's Avatar
yeah you can get a y connector for the an lines.
but its gonna cost $$$$$$$ you will need two bottle openers to open the bottles from inside the cabin.
Old Sep 30, 2003 | 09:07 PM
elchino's Avatar
Or you could just have one bottle opener and switch it over to the one that you plan on using. But keep in mind that if you have one full and one empty and then opened them both, I would think that the pressure would equalize between the two of them.
Really I don't see the point of having two bottles installed if you're not going to run them at the same time. I too have thought about going to two 5 pound bottles. It would be a whole lot easier to tuck away and keep a useable amount of cargo space.
Old Sep 30, 2003 | 10:05 PM
Nismo's Avatar
"I need one of the the big ones, actually lets make it TWO "
sorry couldnt resist
Apr 16, 2020 05:15 AM
worldwiderecognized
Sep 30, 2015 01:16 PM
Socalstillen
Sep 26, 2015 12:01 PM
BrandonCause
Sep 20, 2015 10:20 PM
