BKR6E Gapping?
Old Nov 14, 2003 | 06:27 PM
DOM's Avatar
DOM
BKR6E Gapping?
I Ordered these plugs and I need to gap them. I see everywhere on this site that there are BKR6E-11 plugs, but mine do not have the -11 on the end of it. When I check on the gap coin, It stops on .037 for all of them. What is the exact gap number I should be at if I rarely use a 70 shot?
Also, about the gap coin, do I take measurement when it starts to feel like it is catching, or when I can't move it up on the coin anymore?
Old Nov 14, 2003 | 06:56 PM
SonicDust187's Avatar
I would leave them at that
Old Nov 14, 2003 | 09:32 PM
elchino's Avatar
Agreed. That's about what gap I'm running on 75 shot
Old Nov 15, 2003 | 05:12 AM
Jime's Avatar
1. Don't use the coin gapper they are a POS. Get a proper wire gauge if you want accuracy.
2. My BKR7E's come pre gapped at .035 which is probably what yours are. I leave mine right there.
3. The -11 is 1.1 mm or .044" which is the stock gap for our plugs.
Old Nov 15, 2003 | 02:59 PM
DaThrillr's Avatar
hey u see sonicdust!!!
hey jime is it absolutely necessary to torque ur plugs?? i installed my brk6es-11's with a .035 gap and i torqued them by hand...not too tight not too loose
Old Nov 15, 2003 | 06:48 PM
Jime's Avatar
You should be ok.
I don't own a torque wrench. However, I have been doing this all my life so you sort of get a feel for it. I raced bikes and snowmobiles for a few years and changed plugs on aluminum heads almost daily.
If you don't have experience, get a torque wrench, I have seen many strong arms break stuff and create mega headaches and cost lots of money. Its usually overtightening that causes the problems not the reverse.
Old Nov 15, 2003 | 09:25 PM
CullenJ76's Avatar
Jime: Are the mod's ever going to sticky your plug write-up
Old Nov 16, 2003 | 06:16 AM
Jime's Avatar
I am just in the process of doing a website which I will try and have just about everything I know on. (shouldn't take too much for that)
Going to have a plug page as well as all the other mods I have either adopted or came up with to try and help folks out.
So far I just have the first page but going to start working on it this week.
It located here: or by clicking on the WWW at the bottom.
www.jime.homeftp.net
Old Nov 16, 2003 | 07:46 AM
CullenJ76's Avatar
look's goog so far. Keep it up!
Old Nov 16, 2003 | 07:58 PM
DaThrillr's Avatar
ok thanx jime....
dank4us
34
Jun 10, 2024 03:45 AM
Spartan1310
Sep 28, 2015 08:03 AM
cruce91
Sep 20, 2015 10:23 AM
JoshG
21
Sep 4, 2015 09:04 PM
Turbobink
Aug 15, 2015 07:20 AM
