pics of WOT switch
i am buying my buddy's NOS kit that he had on his chevelle, i would like to see what you guys are using for the WOT switch and how it's mounted and all of that jazz. if you could please post some pics that would be great. thanks
im assuming his chevelle would be carbed and carb kits arnt the same as EFI kits so you may need some other parts that his wont come with for one being fuel jets since carbs run much lower fuel pressure than EFI and also it may have a carb plate which also wont work youll need a fogger nozzle
Mounted on throttle body and arm bent at 90 degree down. http://www.cardomain.com/memberpage/144882/3 |
thanks for the info i know that his kit won't completely just switch over to mine and that i need to get a few things, but it's cheap and he has the bulk of what i need
forgot to ask, being that his setup was a wet direct port one do i still need to upgrade the jets?
HP------N2O------FUEL 35------31--------18 50------35--------20 75------41--------22 100-----52--------31 150-----62--------33 But I would be safe and call NX, their tech support is excellent. www.nitrousexpress.com |
and also i made a mistake, it isn't a NOS kit it's NX i don't want to be one of the guys that refers to nitrous by nos so there you go
If you don't want to use a WOT switch, just use a pushbutton and be sure not to use it at low RMPs
© 2024 MH Sub I, LLC dba Internet Brands
