Walbro 190lph enough for 100 shot??
Old Jul 7, 2005 | 02:23 PM
mjk's Avatar
mjk
Head shot!!!
okay. so I'm running a 50 with a stock fuel system on a 2000 max. It looks like 75 is already sort of pushing it on the stock set up, so I'm wondering if I got a Walbro 190lph would that be enough to take it all the way up to 100shot. I would also go down one step on the plugs.
This is what I don't understand. If I get an aftermarket fuel pump and I need to control it somehow, lets say to a correct afr, does that afr stay when I hit the spray or do I need to have two seperate settings to achieve that? Thanks guys, I know that it's a nwbish question..
Old Jul 7, 2005 | 02:26 PM
mjk's Avatar
mjk
Head shot!!!
nevermind I just read a thread about it... I should have looked... sorry...
Old Jul 7, 2005 | 05:26 PM
JUICED's Avatar
Walbro High-Pressure 255 ltr/hr Fuel Pump! 190=To Low for 100 shot, but you probably already know that. Good luck w/ the 100 shot!
Old Jul 7, 2005 | 06:12 PM
SonicDust187's Avatar
190 high flow is more then enough for 100 shot. and 255 is only needed on a dry setup.
Old Jul 8, 2005 | 07:09 AM
Deckdout2's Avatar
Play with my balls
190 is plenty.......
Old Jul 8, 2005 | 08:10 AM
mjk's Avatar
mjk
Head shot!!!
kool, thanx a lot everyone. Injectors are not needed on a wet set up, right? Since you only need enough to sustain wot fuel requirements for the injectors, and additional fuel that mixes with nitrous right before the intake. Am I right about this? Eaither way I'm glad that its enough
Old Jul 8, 2005 | 06:52 PM
NisMo-Max's Avatar
Where can i Buy a Walbro 190lph Fuel Pump, Well i looked but it doesnt fit my application for the 5th gen, anybody know the part #..
Old Jul 17, 2005 | 07:41 PM
Ammi's Avatar
350 Detroit Muscle
only for dry setup or can it still be used w/ wet setup?
Old Jul 17, 2005 | 09:20 PM
can be used on wet, but you will have to get a fpr.
Old Jul 18, 2005 | 05:47 PM
mjk's Avatar
mjk
Head shot!!!
hmm, i read that you may not need an fpr with the 190, which is why I would go for the 190 and not the 255
Old Jul 18, 2005 | 06:15 PM
jcy98maxse's Avatar
Turbo is too much fun!
with a 190 lph I'm running about 43 psi @ idle and 50ish @ wot. I do have a AFPR that I have yet to install.
Old Jul 18, 2005 | 06:21 PM
Ammi's Avatar
350 Detroit Muscle
you don't need a fpr w/ 190 fuel pump then?
Old Jul 18, 2005 | 08:55 PM
NisMo-Max's Avatar
Is this True???
Old Jul 19, 2005 | 12:23 AM
jcy98maxse's Avatar
its really your own preference. You will run richer without an FPR which some may say could hurt your NA or even nitrous performance however you will be running safer(better to run rich than lean). I got one just because my mpg has been kinda crappy since the new fuel pump (300-310ish compare to 370ish before) that and NX did there bench test their jets @ our stock FP so I feel it'll be better to at least get closer to that FP even with a 190 fuel pump , but its really up to you if you want to get one or not.
Old Jul 19, 2005 | 07:20 AM
with the 190 pump the idle fp only goes up by maybe 1-3 psi.
Old Sep 18, 2005 | 12:45 PM
mjk's Avatar
mjk
Head shot!!!
how about make this a sticky in the n2o section? pretty good info in here...
Old Sep 19, 2005 | 02:59 PM
CalsonicSE's Avatar
I'd say these sort of fuel pressures warrant having an adj. FPR.
Apr 16, 2020 05:15 AM
BkGreen97
Apr 2, 2016 05:47 AM
knight_yyz
Nov 1, 2015 01:34 PM
Andy29
Sep 29, 2015 05:32 AM
