quick spark plug questions
Old Jul 18, 2005 | 04:46 PM
Ammi's Avatar
350 Detroit Muscle
Time for new spark plugs but thinking of trying out Zex kit in the future. I know running nitrous system require colder step plugs. Would there be problem if I run 1 step colder plugs while NA? (so I won't have to replace plugs again if I get the kit)
Old Jul 18, 2005 | 09:07 PM
Ammi's Avatar
350 Detroit Muscle
anyone????
Old Jul 18, 2005 | 11:41 PM
NisMo-Max's Avatar
i hear you may lose a lil power using 1 step colder plugs N/A, But i have my Denso Iridium 1 step colder plugs and i didnt feel a difference when running N/A. But i only changed them because i have the zex wet kit, if your not looking into getting nitrous then i would suggest you get the same heat range as stock....
Old Jul 19, 2005 | 07:37 AM
Deckdout2's Avatar
Play with my balls
I just picked up 2 step colder plugs, and planning on changing them this Saturday. They are the NGK Iridium Plugs. I'll let you know if I feel any difference NA vs Spraying. I got these because Jime runs them and seems to have good results. He stated that they don't burn up as fast as copper does. So we'll see, and I'll keep you informed.
Old Jul 19, 2005 | 10:20 AM
vq356sp's Avatar
El Mas Noob Del Org.
i installed my 2 step colder ngk iridiums this weekend when i got my nx kit put in and i feel the car better maybe cause my plugs were the old stock platinum plugs i dont think it makes a difference i actually feel like it did the car some good probably cause my other plugs had 67000 miles on them but if your getting nitrous you should get them cause its a pain to change them again later.
Old Jul 19, 2005 | 10:53 AM
Ammi's Avatar
350 Detroit Muscle
anyone know if 75 shot can be run w/ 1 step colder plugs?
Old Jul 19, 2005 | 11:47 AM
Deckdout2's Avatar
Play with my balls
Right now I'm running 75 with no colder plugs. Worst even, I'm using the stock platinum..... No harm will be done with being careful. 75 shot with 1 step will be fine.
Old Jul 19, 2005 | 12:07 PM
Brushedpewter's Avatar
Yeah copper burn up fast under nitrous. My one step colder are green after 2 bottles.
Old Jul 19, 2005 | 12:11 PM
Ammi's Avatar
350 Detroit Muscle
ok now my other question is if I do get the 1 step colder plugs, do I still need to re-gap them?
Old Jul 19, 2005 | 02:00 PM
Deckdout2's Avatar
Play with my balls
For 1 step colder I would gap them about 34-35. My 2 step colder will be brought down to 38 from 40. The Factory gap of 39-43. Someone with 1 step colder might be able to chime in as to what theirs is gapped to.
Old Jul 19, 2005 | 02:02 PM
Ammi's Avatar
350 Detroit Muscle
So even OEM replacement plugs need re-gaping?
Old Jul 20, 2005 | 07:28 AM
Deckdout2's Avatar
Play with my balls
Most of the time, the OEM are gapped to specs. but you want to check to make sure. It's not that hard to do, and saves time and money down the road to check the gap before you drop them in.
Old Jul 20, 2005 | 08:15 AM
Ammi's Avatar
350 Detroit Muscle
Do you notice any difference in performance while running your green sparkplugs?
Old Jul 20, 2005 | 10:09 AM
Not really, it just means i'm running too hot. I'm not going to take chances. Until I get a header and do fuel system upgrade I won't spray again. I haven't sprayed since May. Don't take chances because it will kill your motor.
mvm062
Nov 30, 2020 09:00 AM
9aj9
Apr 5, 2020 12:11 AM
Johnny9595
Sep 3, 2015 05:18 AM
sdotcarter
Sep 2, 2015 09:53 PM
maximusrising
Sep 2, 2015 09:55 AM
