How do you run fuel from a fuel cell without running any fuel from fuel tank??
Old Aug 18, 2005 | 07:33 AM
Brushedpewter's Avatar
See title. And without disconnecting any hoses to switch between the 2.
For instance If I want to go to the track and want to run higher octane without putting it in my gas tank.
Old Aug 18, 2005 | 08:04 AM
Jime's Avatar
Here is how I do it on a returnless system by opening one valve and closing another. You will have to figure out how to modify for a return setup but it will take another valve or two.
Old Aug 18, 2005 | 08:26 AM
so you are saying I can run 91 octane from the fuel tank and 100+ from the fuel cell that only goes to the fuel solenoid without tapping the fuel line. Is that possible????
The problem with putting 100+ octane in the fuel tank is that it will mix with regular fuel and I plan to run a very high shot. So I need all the high octane I can get because the timing can't be retarted.
Old Aug 18, 2005 | 08:52 AM
Jime's Avatar
That is the way I usually run mine, fuel from the tank and fuel solenoid from the fuel cell. However the way I have it set up I can also run the engine as well as the fuel solenoid from the fuel cell or I can run tank fuel to the fuel solenoid too.
If you just use the cell for the fuel solenoid the cost of fuel is reduced dramatically as well. I just buy one 2 gal contained at the start of the year and it lasts the season. Sure beats mixing it in the tank.
Old Aug 18, 2005 | 10:18 PM
Then that is what i'll do. What kind of pump can I use on the fuel cell and will a fpr be requared for the fuel cell?
Old Aug 19, 2005 | 03:05 AM
Jime's Avatar
Look at my drawing again. It shows a 255 Walbro External and I am using the Accufab universal FPR both from http://www.autoperformanceengineering.com/.
If you just want to use it for the nitrous just eliminate the line going to valve "B" and it will just feed the nitrous solenoid.
Fitting the 1 gal fuel cell was a chore, the only place I found it would fit is in the cavity where the CAI filter would go and I placed it there on both my 95 and 2k2. Probably not the safest place but I have a line connected to the outlet of the pump which will empty the cell to a fuel can when not in use.
Old Aug 19, 2005 | 10:05 AM
The picture and the drawing help a lot. Thanks.
Also even with the fuel cell do I still need to run a higher flow fuel pump for the car's fuel tank to run a 100+ shot?
And what is the psi that you set the fuel cell fpr?
Old Aug 19, 2005 | 10:46 AM
Jime's Avatar
You can just run the stock pump for the car's tank because its only supplying for the engine just like stock. You also don't need much of a pump for just nitrous either, I got the 255 because I wanted to have the capability to run the car and nitrous from the cell.
My fpr is set for 52 on the 2k2 but I had it set at 43-45 for my 4th Gen.
captchaos
Mar 15, 2016 12:18 PM
97_GXE
Sep 15, 2015 06:47 AM
ballerchris510
Sep 10, 2015 09:35 PM
videomano
Sep 8, 2015 03:28 PM
