zex nitrous kit
Old Aug 26, 2005 | 08:39 PM
qnpark8282's Avatar
zex nitrous kit
Just finished installing my nitrous kit(wet) today. Went out for a test drive and noticed some bucking in 2nd gear. 3rd gear was fine. As of modds i have intake, pulley, and y pipe. I was wonder what it might could have been? Was spraying 55shot. Maybe i should by some colder plugs? I asked around local placed and no one knew what colder plugs meant. Where can i order colder plugs?
Old Aug 27, 2005 | 07:47 AM
Jime's Avatar
What plugs are in it now?
Old Aug 27, 2005 | 08:50 AM
vq356sp's Avatar
El Mas Noob Del Org.
go to www.sparkplugs.com thats where i got mine they even explain what you need on there site i had the same problem when i was trying to get my plugs no autopart place even knew they existed but on this site they have all the hard to get spark plugs there very quick i got my plugs the day after i placed my order check em out.
Old Aug 27, 2005 | 08:48 PM
qnpark8282's Avatar
Jime i believe stock plugs are in there right now.
Old Aug 30, 2005 | 03:53 AM
Jime's Avatar
If they are get them out pronto, nitrous and platinum plugs do NOT mix.
Either copper or irridums will work fine althoug I prefer the irridums after a year of using them.
Check this pic for what plug you need. Higher numbers are colder.
Old Aug 30, 2005 | 09:07 AM
bad02max's Avatar
Zex also makes their own spark plugs to go with the kit.
Old Sep 1, 2005 | 01:52 PM
Superalty's Avatar
Zex plugs suck. Car never seemed as powerful with, according to the seat 'o pants dyno. Then again I had to adjust the gap on the plugs because at least one prong per plug was wrong. Stick to coppers or iridiums (which I run now).
Apr 16, 2020 05:15 AM
Kyle Lee Cleveland
Sep 28, 2015 07:58 AM
Pied
Sep 26, 2015 03:29 PM
