smaller shot on a direct port setup
Old Sep 20, 2005 | 10:32 PM
mad-max98's Avatar
i was wondering if there is anyway we can make the nozzle run less nitrous .. i'm trying to run multi stage direct port on a turbo max but the smallest i've seen is 140-150 shot which is too much
Old Sep 20, 2005 | 11:43 PM
mtrai760's Avatar
'Trynna' is not a word
Yes, you can run smaller than that. You just need to get new jets for it. What brand kit are you looking at?
Old Sep 21, 2005 | 12:51 AM
mad-max98's Avatar
zex or nx but when i looked they don't have that small of nozzles ,, i need something for 60 max so that means 10 for each nozzle but the smallest is like 30
Old Sep 21, 2005 | 03:53 AM
Jime's Avatar
The only way you can do it DP is by running a separate fpr and going down to the 10 psi like the carburated cars do and then you can use larger jets. Otherwise you won't be able to get jets that small.
Old Sep 21, 2005 | 04:35 PM
mad-max98's Avatar
won't that affect the spray pattern though
Old Sep 21, 2005 | 05:02 PM
Jime's Avatar
How do you think all the v8 guys run N2O? At low pressure. The spray pattern is created by the nitrous pressure not the fuel pressure.
If you look at most v8 setups they run in the 6-7 psi range. Heck their gauges only read from 0-12 psi. They all use a separate fpr for nitrous. If you look at most of the venders they sell 2 types of nitrous kits, one for EFI and one for carburated which are the low pressure types.
Old Sep 25, 2005 | 06:18 AM
mad-max98's Avatar
cool that's a new hope for my setup
Old Sep 25, 2005 | 07:53 PM
SR20DEN's Avatar
VQ Wizard
The smallest Jet you can get is .014". Six of those will certainly equal more than 60hp.
Old Sep 26, 2005 | 04:04 AM
mad-max98's Avatar
question, i have a vortech sfmu laying around how can i take advantage in a setup like that?
Old Sep 28, 2005 | 09:48 AM
1MAX2NV's Avatar
The smallest you can go is around 50-60 shot with NOS brand. I forgot what jet size. I believe .014 nitrous and .016 fuel.
Old Sep 28, 2005 | 09:50 AM
1MAX2NV's Avatar
You would still need to run another FPR after the Vortech SFMU to bump up the fuel pressure back to stock spec.
Apr 16, 2020 05:15 AM
trsandrew
Apr 8, 2016 06:45 PM
magiconthetire
Oct 26, 2015 09:03 PM
trsandrew
Oct 25, 2015 02:47 PM
JonBlz
Oct 5, 2015 06:02 PM
