need some help picking a kit
Old Nov 17, 2005 | 08:23 PM
d1max2nv's Avatar
So i finaly decided to get a ZEX kit for christmas, well i check on custommaxima, and i saw the dry kit was 509, and the wet was something like 575, well i was wondering is there really a big of a difference between wet and dry? and how much more hp does the wet system make? thanks in advance.
Old Nov 18, 2005 | 09:14 AM
desertmaxima's Avatar
Just go with wet it is easier to upgrade shots on those and tune it better than te dry. if I had to do it all over again I would have went wet
Old Nov 18, 2005 | 09:43 AM
CalsonicSE's Avatar
I'd go with wet if I didn't have the MEVI. Heard fuel may puddle on the MEVI valves. Anyway, my dry shot has always given me good results.
Old Dec 9, 2005 | 12:01 PM
streetzlegend's Avatar
just go to the 1st sticky and purchase that kit. i ordered it today and also got a discount cuz i had a coupon code. which is Jan30 and you get $30 off. mine totaled to 428. i have herd this is a great kit.
Old Dec 9, 2005 | 12:06 PM
NisMo-Max's Avatar
I bought my Wet Zex 75 shot kit for 525 shippped with importcarpartsplus in the group deals forum check it out...
Old Dec 9, 2005 | 12:19 PM
C MAX's Avatar
my first kit was a dry kit and i used up to a 70 shot and it worked pretty well. i converted to a wet kit by adding a fuel solenoid and now run up to a 100 shot. as far as power wise i dont think theres any difference except on the dry kit you rely on your injectors to deliver fuel which can become taxing after a 70 shot, so if you wanna go higher than that go wet.
Old Dec 12, 2005 | 11:54 AM
00SEMAX19's Avatar
Thanks! Just saw your post and used your discount code. couldn't resist and now it's on the way
Old Dec 12, 2005 | 12:35 PM
00SEMAX19's Avatar
The nopi kit in the first stickie says 35-50-75hp. Does this mean it comes with all 3 options?
Old Dec 12, 2005 | 12:40 PM
NisMo-Max's Avatar
Yes, those are the different jets that provide how much horsepower you want to adjust on your kit.
Old Dec 12, 2005 | 01:43 PM
00SEMAX19's Avatar
Cool, I'll probly just through in the 50 untill I get some other upgrades.
Fuel pump and plugs should be all I really need right?
Old Dec 12, 2005 | 06:48 PM
DonGfun's Avatar
VW = 30 MPG
Just plugs & bottle heater ... Thats all I got so far
I also have the Nopi kit. I got last year for $440 ... Great kit
Old Jan 1, 2006 | 09:48 PM
Hey so give us an update on the kit.
Old Jan 2, 2006 | 08:34 AM
00SEMAX19's Avatar
Ya talking to me? If so, The shipping was fast (less than a week) Everything seems to be good quality exept for the cheap arming switch. My install is only half finished, basically all the pluming is done and I just need to do a little wiring. The bottle is filled and ready to go. If I have time and am not to busy at work I should be able to complete and give more feedback today or tomorrow.
And one question, Where should I put the Wide open throttle switch?
Old Jan 2, 2006 | 09:32 PM
yea i was refering to you. just wanted to know how ur install went. mine went pretty smooth only had problems with the T fitting they provided which is crap so i made my own according to the one Jime showed on another thread.
Old Jan 8, 2006 | 06:56 PM
Da Great 1's Avatar
kit
I just got the Nitrous Express F&F Stage I Shark is great kit, its cost about 860 dollars but its a great kit, you get 35 to 150 HP shots.... check it out...http://www.cardomain.com/item/NIE22923
Old Jan 9, 2006 | 05:25 AM
wow but that sounds quite expensive though. You didnt read the 1st sticky under this nitrous forum? NX kit for 440. but i guess with the blowdown tube, pressure relief valve and remote pressure gauge it all adds up, but nice kit. Have you installed it?
Old Jan 9, 2006 | 11:07 PM
Da Great 1's Avatar
yea, i got it installed, love it, dont use it to much, only if i need 2, works great,yea it was expiense but it was worth the money
Old Jan 10, 2006 | 10:31 PM
Donkeypunch's Avatar
Did you get the kit?
Sometimes you get lucky if you wait and search.
I got a used nos (dry) kit for $170. Came with everything, even a purge valve and
an autometer guage.
Just got a bottle heater and blanket and so now I have a pretty decent street setup for a really cheap price.
BTW: a bottle heater is almost a must! Not really in the summer days though.
sucks I have to ***** 15 posts just to make 1 thread :P
Old Jan 16, 2006 | 11:04 AM
00SEMAX19's Avatar
Well it's finally done...3.5 and nitrous=instant hard on. Car really halls *** now. It's been basically completely installed for the last 2 weeks but I've been hesitant to cut into my fuel hose. I couldnt' wait any longer so I finished it up this morning and took it for a test drive. I only have the 35 shot in now untill I get some new plugs but even with a small shot it makes a huge difference. I can't wait to move to the 75 shot and really move. Every thing on the kit was good exept the ****ty little T they give you to tap into the fuel hose. I can't coplain though, everything works perfect. I'll get some pics of my install up after I clean it up a bit.
Old Jan 20, 2006 | 09:25 AM
nice. congrats! welcome to the club, now what did you do about the gay T fitting? did you make your own?
Old Jan 20, 2006 | 12:02 PM
00SEMAX19's Avatar
I used the one that came with the kit...I'm still not comfortable with it, and on the search for something better. I check it daily though, and not problems as of yet. I havn't been spraying to much because I have no Idea how much pressure is in the bottle. I know not enough fuel will make me lean out and have problems, but what is the worst that can happen with not enough nitrous and being to rich?
Old Jan 20, 2006 | 01:08 PM
Worst thing I think you can get is a backfire and blow your airbox off.
A guage and bottle heater is pretty much a must.
It turnes out, without the heater I would never get past 700psi on a full tank.
Now it's at 950 and pulls much harder and lasts just as long.
Old Jan 25, 2006 | 03:39 PM
thebeet's Avatar
Who does installs in Dallas ,Texas ???
Old Jan 28, 2006 | 06:30 AM
Yea if you spray more fuel than nitrous you are running the risk of the fuel getting puddled up inside the intake manifold and when there is a spark right before the intake valve closes the puddled fuel sitting there will ignite blowing your intake manifold apart, or in some cases just blow your MAF, Filter and intake manfold gasket. you can buy a bottle pressure gauge very cheap at summit racing. its 16 bucks and it screws into the side port of the bottle. If you put the T fitting after the fuel filter i strongly suggest you look for something better ASAP, it is just to small and at anytime can come off and spray fuel everywhere probably causing your car to burn to the ground if the engine bay is hot enough..
Old Jan 28, 2006 | 01:28 PM
SEBOY's Avatar
hey guys what sup i just order a zex kit for 2004 maxima se automatic where i can find upgrades to it thanks
Old Jan 29, 2006 | 08:02 PM
For sure get a bottle heater and bottle blanket.
Get a pressure activated kit, it'll heat up faster.
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
maxima-junky
Oct 7, 2015 06:13 PM
REDinLV
Sep 28, 2015 12:31 AM
Pied
Sep 26, 2015 03:29 PM
worldwiderecognized
Sep 24, 2015 06:56 PM
